Problems with Virtual XP Mode after hardware upgrade...
  1. Posts : 65
    Windows 7 64 bit
    I recently upgraded my motherboard to a Gigabyte 990FXA-UD3 and my processor to an AMD FX-6300. I also replaced the Kingston memory with G. Skill. Since the change, the integration features of XP Mode refuse to activate. I have SVM virtualization enabled in the BIOS and the FX-6300 supports virtualization. All the drives remained the same.
    I would appreciate any guidance on restoring my virtual machine to working order.
  2. Posts : 65
    Windows 7 64 bit
    In settings the integration features are showing as unavailable and the enable integration features at startup tickbox is checked but grayed out. I can point the settings to my integration components iso and tell it to open it but nothing happens.
  3. Posts : 65
    Windows 7 64 bit
    Solved it with an XP system restore!
    Hadn't thought about that in the context of a virtual machine.
  4. Posts : 65
    Windows 7 64 bit
    Well I thought that worked but tonight I'm back to the same issue and restoring ISN'T working!
    How can I install my integration components from a black screen? I have the option under Tools but what do I do?
    Should I just save my .vhd file and uninstall and reinstall Virtual PC and Windows XP Mode?
  5. Posts : 65
    Windows 7 64 bit
    Apparently virtualization issues are a more difficult nut to crack than I thought. Not a single response!
