Help i need help with bsod blue screen problems
Hi all i hope you can help me,i have a lot of bsod blue screen error i will put them here to look at them and maybe someone can help me.thanks
Hy again pls help me pls dont know what to do.....here i follow the steps from tutorial of forum post files i hope this one is good!
Sorry for the late response Been rather sick for the past few days. But I had a look through your files and if you could please do the following:
Enable driver verifier and allow it to crash your computer, if it has not crashed within 24 hours move on to the next step:
Driver Verifier - Enable and Disable
Tip: If you can not boot normally into windows after enabling Driver Verifier please boot into safe mode and then disable driver verifier.
If Driver verifier does not cause a crash after 24 hours please run memtest86+ for at least 8 passes:
RAM - Test with Memtest86+
Tip: Do this over night it can take a long time
