IDE Maxtor 250gb Hard drive Problem.
  1. Posts : 3
    Windows 7 Ultimate x86
    Hello, I've recently done a clean install of Windows 7 Ultimate and one of my harddrives is not showing up correctly. The harddrive itself is my Local Disk D, it hasn't got any system files on it however it is displaying at the wrong size:
    The problem lies in the fact that on boot my Computer's BIOS detects the harddrive as a 233GB harddrive. This is not a problem as I understand that the harddrive itself isn't the exact size as what it says on the box, however the Windows 7 installation and Windows itself only detects the harddrive as being 148gb.
    What I've Tried Doing:
    • I've tried different things to resolve this issue. I've looked at the Disk Management, but there are no extra partitions and I've also looked at the harddrive in Partition Manager which again only picked up 149gb and no unallocated space.
    • I've run a partition recovery tool in Partition Manager which did not detect any lost partitions containing the rest of the harddrive.
    My System:
    System Information
    Time of this report: 10/18/2010, 18:30:10
    Machine name: SAM-PC
    Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
    Language: English (Regional Setting: English)
    System Manufacturer: To Be Filled By O.E.M.
    System Model: To Be Filled By O.E.M.
    BIOS: BIOS Date: 09/23/03 17:35:41 Ver: 08.00.09
    Processor: AMD Opteron(tm) Processor 146, ~2.0GHz
    Memory: 2046MB RAM
    Available OS Memory: 2046MB RAM
    Page File: 890MB used, 3202MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7600.16385 32bit Unicode
    DxDiag Notes
    Display Tab 1: No problems found.
    Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
    Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (retail)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: RADEON X800 PRO (Microsoft Corporation - WDDM)
    Manufacturer: ATI Technologies Inc.
    Chip type:
    DAC type: Internal DAC(400MHz)
    Device Key: Enum\PCI\VEN_1002&DEV_4A49&SUBSYS_00021002&REV_00
    Display Memory: 319 MB
    Dedicated Memory: 255 MB
    Shared Memory: 63 MB
    Current Mode: 1440 x 900 (32 bit) (60Hz)
    Monitor Name: Generic PnP Monitor
    Monitor Model: Acer AL1916W
    Monitor Id: ACRAD52
    Native Mode: 1440 x 900(p) (59.887Hz)
    Output Type: HD15
    Driver Name: atiumdag.dll,atiumdva.cap,atitmmxx
    Driver File Version: 8.14.0010.0630 (English)
    Driver Version: 8.56.1.15
    DDI Version: 9Ex
    Driver Model: WDDM 1.0
    Driver Attributes: Final Retail
    Driver Date/Size: 7/14/2009 02:14:55, 4030976 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp:
    Device Identifier: {D7B71EE2-0909-11CF-C471-0820A1C2C535}
    Vendor ID: 0x1002
    Device ID: 0x4A49
    SubSys ID: 0x00021002
    Revision ID: 0x0000
    Driver Strong Name: atiilhag.inf:ATI.Mfg.NTx86...1:ati2mtag_R420:8.56.1.15:pci\ven_1002&dev_4a49
    Rank Of Driver: 00F42001
    Video Accel: ModeMPEG2_A ModeMPEG2_C
    Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    D3D9 Overlay: Not Supported
    DXVA-HD: Not Supported
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    Sound Devices
    Description:
    Default Sound Playback: No
    Default Voice Playback: No
    Hardware ID:
    Manufacturer ID:
    Product ID:
    Type:
    Driver Name:
    Driver Version:
    Driver Attributes:
    WHQL Logo'd:
    Date and Size:
    Other Files:
    Driver Provider:
    HW Accel Level: Emulation Only
    Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
    Static/Strm HW Mix Bufs: 0, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Sound Capture Devices
    DirectInput Devices
    Device Name: Mouse
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Keyboard
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Poll w/ Interrupt: No
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x1106, 0x3038
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 7/14/2009 00:52:09, 258560 bytes
    | Driver: usbd.sys, 7/14/2009 00:51:05, 5888 bytes
    Gameport Devices
    PS/2 Devices
    + Standard PS/2 Keyboard
    | Matching Device ID: *pnp0303
    | Service: i8042prt
    | Driver: i8042prt.sys, 7/14/2009 00:11:24, 80896 bytes
    | Driver: kbdclass.sys, 7/14/2009 02:20:36, 42576 bytes
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    + HID-compliant mouse
    | Vendor/Product ID: 0x0461, 0x4D22
    | Matching Device ID: hid_device_system_mouse
    | Service: mouhid
    | Driver: mouhid.sys, 7/14/2009 00:45:08, 26112 bytes
    | Driver: mouclass.sys, 7/14/2009 02:20:44, 41552 bytes
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    | Driver: termdd.sys, 7/14/2009 02:19:10, 51776 bytes
    | Driver: sermouse.sys, 7/14/2009 00:45:08, 19968 bytes
    Disk & DVD/CD-ROM Drives
    Drive: C:
    Free Space: 105.5 GB
    Total Space: 114.5 GB
    File System: NTFS
    Model: ST912082 SCSI Disk Device
    Drive: D:
    Free Space: 152.4 GB
    Total Space: 152.5 GB
    File System: NTFS
    Model: SAMSUNG SCSI Disk Device
    Drive: E:
    Model: OPTORITE DVD RW DD0201 ATA Device
    Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/14/2009 00:11:26, 108544 bytes
    System Devices
    Name: VIA Standard CPU to PCI Bridge
    Device ID: PCI\VEN_1106&DEV_3188&SUBSYS_80A31043&REV_01\3&267A616A&0&00
    Driver: n/a
    Name: VIA Rev 5 or later USB Universal Host Controller
    Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_80ED1043&REV_81\3&267A616A&0&80
    Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/14/2009 00:51:10, 24064 bytes
    Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/14/2009 00:51:15, 284160 bytes
    Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/14/2009 00:52:09, 258560 bytes
    Name: RADEON X800 PRO Secondary (Microsoft Corporation - WDDM)
    Device ID: PCI\VEN_1002&DEV_4A69&SUBSYS_00031002&REV_00\4&3600494A&0&0108
    Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.0859 (English), 7/13/2009 23:09:17, 4194816 bytes
    Driver: C:\Windows\system32\DRIVERS\ativcaxx.cpa, 6/10/2009 22:19:15, 328162 bytes
    Driver: C:\Windows\system32\DRIVERS\ativcaxx.vp, 6/10/2009 22:19:15, 929 bytes
    Driver: C:\Windows\system32\DRIVERS\ativvpxx.vp, 6/10/2009 22:19:15, 52400 bytes
    Driver: C:\Windows\system32\DRIVERS\ativpkxx.vp, 6/10/2009 22:19:15, 2096 bytes
    Driver: C:\Windows\system32\DRIVERS\ativokxx.vp, 6/10/2009 22:19:15, 2096 bytes
    Driver: C:\Windows\system32\DRIVERS\ativdkxx.vp, 6/10/2009 22:19:15, 2096 bytes
    Driver: C:\Windows\system32\atiumdag.dll, 8.14.0010.0630 (English), 7/14/2009 02:14:55, 4030976 bytes
    Driver: C:\Windows\system32\atiumdva.dll, 7.14.0010.0208 (English), 7/14/2009 02:14:57, 4772352 bytes
    Driver: C:\Windows\system32\amdpcom32.dll, 7.14.0010.0018 (English), 7/14/2009 02:14:53, 50688 bytes
    Driver: C:\Windows\system32\atiumdva.cap, 6/10/2009 22:19:14, 69112 bytes
    Name: VIA VT8237 RAID Controller
    Device ID: PCI\VEN_1106&DEV_3149&SUBSYS_80ED1043&REV_80\3&267A616A&0&78
    Driver: C:\Windows\system32\DRIVERS\vsmraid.sys, 6.00.6000.6210 (English), 7/14/2009 02:19:11, 141904 bytes
    Name: VIA Bus Master IDE Controller - 0571
    Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711106&REV_06\3&267A616A&0&79
    Driver: C:\Windows\system32\DRIVERS\viaide.sys, 6.00.6000.0170 (English), 7/14/2009 02:19:10, 16976 bytes
    Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 02:19:03, 42560 bytes
    Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 02:26:15, 21584 bytes
    Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/14/2009 02:26:15, 133200 bytes
    Name: RADEON X800 PRO (Microsoft Corporation - WDDM)
    Device ID: PCI\VEN_1002&DEV_4A49&SUBSYS_00021002&REV_00\4&3600494A&0&0008
    Name: VIA USB Enhanced Host Controller
    Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_80ED1043&REV_86\3&267A616A&0&84
    Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/14/2009 00:51:14, 41472 bytes
    Name: 3Com 3C940 Gigabit LOM Ethernet Adapter
    Device ID: PCI\VEN_10B7&DEV_1700&SUBSYS_80EB1043&REV_12\3&267A616A&0&50
    Driver: C:\Windows\system32\DRIVERS\yk62x86.sys, 11.00.0005.0003 (English), 7/13/2009 23:02:53, 311296 bytes
    Name: Multimedia Audio Controller
    Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_80F31043&REV_60\3&267A616A&0&8D
    Driver: n/a
    Name: RAID Controller
    Device ID: PCI\VEN_105A&DEV_3373&SUBSYS_80F51043&REV_02\3&267A616A&0&40
    Driver: n/a
    Name: VIA 1394 OHCI Compliant Host Controller
    Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_808A1043&REV_80\3&267A616A&0&38
    Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/14/2009 00:52:00, 163328 bytes
    Name: AMD Miscellaneous Configuration
    Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&267A616A&0&C3
    Driver: n/a
    Name: Network Controller
    Device ID: PCI\VEN_1814&DEV_0301&SUBSYS_00551737&REV_00\3&267A616A&0&70
    Driver: n/a
    Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_80ED1043&REV_81\3&267A616A&0&83
    Name: AMD DRAM and HyperTransport(tm) Trace Mode Configuration
    Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&267A616A&0&C2
    Driver: n/a
    Name: VIA CPU to AGP Controller
    Device ID: PCI\VEN_1106&DEV_B188&SUBSYS_00000000&REV_00\3&267A616A&0&08
    Driver: C:\Windows\system32\DRIVERS\GAGP30KX.SYS, 6.01.7600.16385 (English), 7/14/2009 02:20:28, 57936 bytes
    Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_80ED1043&REV_81\3&267A616A&0&82
    Name: AMD Address Map Configuration
    Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&267A616A&0&C1
    Driver: n/a
    Name: VIA Standard PCI to ISA Bridge
    Device ID: PCI\VEN_1106&DEV_3227&SUBSYS_80ED1043&REV_00\3&267A616A&0&88
    Driver: n/a
    Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_80ED1043&REV_81\3&267A616A&0&81
    Name: AMD HyperTransport(tm) Configuration
    Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&267A616A&0&C0
    Driver: n/a
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
    DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
    Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16385
    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
    AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16385
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16385
    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16385
    CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16385
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
    VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16385
    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
    SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16385
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16385
    DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16385
    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16385
    Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16385
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7600.16385
    Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16385
    Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16385
    VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
    File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
    iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
    iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
    DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
    Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
    Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7600.16385
    AVI Draw,0x00600064,9,1,quartz.dll,6.06.7600.16385
    RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
    WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
    SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
    Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7600.16385
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16385
    NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16385
    Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
    MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
    File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16385
    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
    StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
    AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16385
    File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16385
    File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16385
    Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
    AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
    AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
    SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16385
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16385
    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
    WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16385
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16385
    GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16385
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16385
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16385
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16385
    PBDA CP Filters:
    PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16385
    PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
    PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16385
    BDA Network Providers:
    Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16385
    Multi-Instance Capable VBI Codecs:
    BDA Transport Information Renderers:
    BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
    MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
    Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
    PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
    XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
    Audio Renderers:
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16385
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16385
    EVR Power Information
    Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
    Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
    Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
    PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
  2. Posts : 6,292
    Hello samboyd93. Welcome to the forum.
    The only thing I can think of is that the drive is set as a SATA2 drive on an older computer that only does SATA1 (please fill in your "My System Specs" to help avoid these kinds of guesses) although I doubt it.
    If you look at the back of the HDD there are jumper pins. Setting a jumper sets the SATA speed on most drives. You may need to consult the HDD's documentation to see what the different jumper positions do. Every manufacturer has a different setup.
    I would try setting the drive as SATA1 to test. But both drives should be at the same setting. Also try plugging the problem drive into a different port or using a different SATA cable. Can't hurt, might help.
    You should also go into your BIOS and check the settings for that drive and compare them to the settings for the other drive. They should be the same.
    Hope that helps.
  3. Posts : 14,606
    there is possibly a hidden recycle bin that has a reason for discrepancy, i had a prob of 50 odd GB missing and this was the soloution,
    will search for my thread about that then get back
    EDIT: ok back now the thread is HERE and has a load of helpful info ,its worth a check !
  4. Posts : 2,009
    Seeing how Maxtor is now Seagate, I would run the SeaTool to determine the actual state of your drive. ~100 GB don't just disappear into thin air.
    -DG
  5. Posts : 6,879
    Win 7 Ultimate x64
    What is the make and model of the motherboard? It may take an install of proper motherboard/chipset drivers (if available) other than the ones that Windows installs by default .Also both drives are showing as SCSI drives,
    Drive: C:
    File System: NTFS
    Drive: D:
    File System: NTFS
    which is probably contributing to the problem.
  6. Posts : 2,009
    mmm I should have read that System report better
    There is a Seagate ST 912082 (which is a 2.5" 120GB IDE or Sata drive)
    and a Samsung 152 GB scsi without closer specification ???
    where is the maxtore?
  7. Posts : 3
    I should explain the issue further to help you all out:
    Currently, I have three harddrives in my computer: the 120gb 2.5" Seagate, a 160gb Samsung HD16OJJ and the problematic Maxtor. I don't know much about the Maxtor, but it reads on it: "Maxtor DiamondMax 16 250GB ATA/133 HDD.
    The 2.5" 120gb is a new addition to my motherboard (Asus SK8V) which I added the day before the initial post in this thread. This replaced a 160gb Samsung HD161HJ which stopped working after I left my computer idle for 45 minutes. When it broke, it took with it my second RAID slot on my motherboard.
    I use a lot of space on my computer, so I decided I would migrate to not using RAID so that I could still have three hard drives and just use the normal SATA slots. My 250GB has been on my motherboard's one IDE slot all this time and worked fine, but now I've turned RAID off and switched to turning off my Promise drivers or running in Onboard IDE Operations (Is that what it's called?) it only reads as 149GB. It worked perfectly fine before my RAID went bust and I had to migrate to the normal SATA slots and even if I turn back to RAID, windows dosen't like detecting the full 250GB.
    As for what you pointed out stormy and Sledge, I don't know why it's not appearing in my DxDiag. It does appears in the BIOS at the correct size, but it is registring in Windows itself at the wrong size.
  8. Posts : 8,870
    Most likely the drive has an extra partition on it. You can try cleaning the partitions by using the the diskpart commands. The "clean" command "fast" should get rid of the extra partition if there is one. The "clean all" command is for rezeroing the drive, takes forever.
  9. Posts : 3
    Thank you for all of your help, but I resolved the issue. I do not know why, but force-installing the Windows XP drivers for the Promise Sata378 solved the issue and made Windows show the proper space. I don't understand why this made a difference, especially as these are XP drivers and it may be tempormental but it will get me by. :)
  10. Posts : 2,009
    Glad you worked it out.
    Thanks for the feedback
    -DG
