Enable test mode to solve USB problems?
Page 3 of 32 FirstFirst 1234513 ... LastLast
  1. Posts : 21,004
       #21
    CrabbyRightNow said:
    Thanks. I hope this does not require that I get into the bios because this computer will only let you change the boot order. That's as far as you can get. Someone else was complaining about this in another forum.
    Gator, do you live in Ft. Myers? I'm in Cape Coral.
    Well I am not that intuitive as most but I have to say not having the BIOS available is very odd if not downright suspicious.
    Have you updated at any time??
  2. Posts : 6,458
       #22
    The fix for the mapi32.dll error in the SFC report won't do anything for the USB issue.
    Download DriverCleanup.zip
    Extract all from the compressed folder - just select the default location provided in the extract window
    A new explorer widow should open showing the extracted files
    navigate to the x64 folder
    Right click on DriveCleanup
    select Run as administrator
    Author's anchor to DriveCleanup
    DriveCleanup removes all currently non present "Storage Volumes", "Disk", "CDROM", "Floppy" USB drives and their USB devices from the device tree. Furthermore it removes orphaned registry items related to these device types. Since V0.8 it removes WPD devices under Vista and Win7/8/10.
    Started with parameter -T (like test) it shows which devices it would remove.
    DriveCleanup -T
    Started with admin privileges and without a parameter it does its job without further inquiry.
    To remove certain types of devices there are the parameters -U -D -C -F -V -W and -R.
    Sample to remove abandoned registry entries only:
    drivecleanup -R
    Under x64 editions of Windows only the included x64 version works.
    Admin privileges are required for actual cleanup, without it switches into the test mode.
    Scroll up to the top of the command prompt window and make sure it did not run in test mode. If it says test mode, then your did not Run as administrator. please try again. You can close the command prompt window.
    Then please post a screenshot of Device Manager showing
    any unknown devices
    any devices with error icons
    These should be easy to spot, the device category should already be expanded to any device that meets that criteria (unknown or problem)
    See: Screenshots and Files - Upload and Post in Seven Forums
    I'll probably want to see another one showing the Universal Serial Bus Controllers, but I'm not sure which ones to look at - there are probably quite a few entries in that category.
    Let me see what I can see and I'll try to figure out the best way to get more information.
    Bill
  3. Posts : 6,458
       #23
    John, it's an HP - they lock the user out of BIOS to protect them. The default settings work for the most part, but it gets frustrating when someone asks you to change a BIOS setting and you can't.
    I spent quite a while trying to figure out if my machine was configured AHCI or IDE. The HP documentation did not help until I dug way down and learned that HP sets the default to AHCI - makes perfect sense, but they should really tell us up front what the settings are.
    You make a good point about the BIOS version - it might be something to look into and a BIOS update might force the USB ports to be recognized.
    I'll gather some information and try to work out the steps.
    @CrabbyRightNow: Since John asked about the BIOS, it would be good to know about that and other aspects of your machine.
    Please follow this tutorial to provide the current operating environment of your machine.
    Speccy - Publish Snapshot of your System Specs
  4. Posts : 21,004
       #24
    Ok Bill didn't know that about them (HP) - thought all BIOS's were accessible
    I think your point re other aspects of the machine would be good too.
  5. Posts : 21,004
       #25
    Bill just noticed in crabby's specs the machine is quoted a desktop yet the rest is notebook so Crabby what actually is it desk or lap - top please?
    Ok looks like a bloat filled laptop and this is interesting as there loks to be two ways of accessing the BIOS
    how to enter bios pavilion dv7 - HP Support Forum - 1009781
  6. Posts : 6,458
       #26
    Crabby probably didn't notice the dropdown box for that field.
    Specs entry error - look below PC/Desktop and you'll see: HP Pavilian DV7-7012 notebook
    HP Pavilion dv7-7012nr Entertainment Notebook PC
  7. Posts : 21,482
    Win 7 x64 Home Premium (and x86 VirtualBox VM)/Win10
       #27
    Here's the condensed part ot the SFC log...
     Line 13025: 2015-01-10 22:43:59, Info                  CSI    0000031f [SR] Repairing 1 components
     Line 13026: 2015-01-10 22:43:59, Info                  CSI    00000320 [SR] Beginning Verify and Repair transaction
     Line 13029: 2015-01-10 22:43:59, Info                  CSI    00000322 [SR] Cannot repair member file [l:20{10}]"mapi32.dll" of Microsoft-Windows-Mapi, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
     Line 13032: 2015-01-10 22:43:59, Info                  CSI    00000324 [SR] Cannot repair member file [l:20{10}]"mapi32.dll" of Microsoft-Windows-Mapi, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
     Line 13033: 2015-01-10 22:43:59, Info                  CSI    00000325 [SR] This component was referenced by [l:202{101}]"Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.WindowsFoundationDelivery"
     Line 13038: 2015-01-10 22:43:59, Info                  CSI    00000328 [SR] Could not reproject corrupted file [ml:48{24},l:46{23}]"\??\C:\Windows\SysWOW64"\[l:20{10}]"mapi32.dll"; source file in store is also corrupted
     Line 13043: 2015-01-10 22:43:59, Info                  CSI    0000032a [SR] Repair complete
    As Gator says, this is hardly a critical system file - and I don't really see it causing your problems. I can see no other significant errors in the CBS background data.
    I'll post a fix protocol for it a little later.
  8. Posts : 131
    Windows 7 Home Premium 64 bit
       #28
    Thanks to everyone for the suggestions. Should I run the drivercleanup.exe now or wait for Noel's fix?
    Yes, this is a bloat-filled HP notebook.
  9. Posts : 21,482
       #29
    I've uploaded a file - crnaa.zip - to my OneDrive at Noel's OneDrive
    Please download and save it.
    Right-click on the saved file and select Extract all...
    Change the target to C:\ and click on Extract
    Close all windows (it would be a good idea to print these instructions!)
    Now reboot to the Repair Environment - as soon as the machine restarts, start tapping F8 - this should bring up the Advanced Boot Menu, at the top of which should be the option 'Repair my Computer'
    Pick that
    You'll have to log in with your username and password.
    Pick the option to use a Command Prompt
    At the prompt type
    DIR C:\crnaa
    hit the enter key - if you get a 'Not Found' error try
    DIR D:\crnaa
    or
    DIR E:\crnaa
    The drive letter in use when you find the folder will need to be substituted (for<drive>) into the following command...
    XCOPY <drive>:\crnaa <drive>:\windows\winsxs /y /i /s /v /h
    (e.g. XCOPY P:\wfire P:\windows\winsxs /y /i /s /v /h )
    run the command (it should take almost no time) and when the prompt returns, type
    EXIT
    and hit the Enter key to exit Command Prompt - reboot to Normal Mode Windows.
    Now run SFC /SCANNOW in an Elevated Command Prompt
    then reboot and upload the new CBS.log file to your reply
  10. Posts : 6,458
       #30
    Do Noel's patch first, then DriverCleanup and the other things I requested.
    I do want to verify the model number though. I posted links to the NR model, I'll double check HP to see if there is more than one model for your machine, but there's usually a link in your start menu or bookmarks that take you directly to the support page.
    The HP assistant might also give you that information or link - it's HP bloat, but it has at least one good virtue.
    edit: searching HP for DV7-7012 only turned up the NR model so I probably have the right links.
