Tip for laptop users: battery condition, sleep problems
  1. Posts : 17,545
    Windows 10 Pro x64 EN-GB
    Lot of us Seven users have a laptop as a main computer. Todays new Dells, HP's, Sonys and Toshibas are so advanced and powerful you can do marvels with them.
    The laptop's battery is a consumer product. Battery capacity will fade little by little, and you often notice a weakened capacity of the battery first when it does not last a lunch break surfing the Web.
    If you are interested to see a full report of your laptop's barrery condition you can get it by running command prompt as an administrator and giving the command powercfg -energy. It creates a HTML file Energy-report.html.
    Energy-report shows everything worth to know about your battery. For instance, it tells you if a program or device is preventing your laptop to sleep or hibernate:
    System Availability Requests:System Required Request
    The device or driver has made a request to prevent the system from automatically entering sleep.
    Requesting Driver Instance: HDAUDIO\FUNC_01&VEN_111D&DEV_76B2&SUBSYS_103C30F4&REV_1003\4&752edf3&0&0001
    Requesting Driver Device: IDT High Definition Audio CODEC
    USB Suspend:USB Device not Entering Suspend
    The USB device did not enter the Suspend state. Processor power management may be prevented if a USB device does not enter the Suspend state when not in use.
    Device Name: Generic USB Hub
    Host Controller ID: PCI\VEN_8086&DEV_293A
    Host Controller Location: PCI bus 0, device 29, function 7
    Device ID: USB\VID_050D&PID_0237
    Port Path: 2
    Maybe the most valuable piece of information is found at the end of the report:
    Battery ID: Hewlett-Packard
    Primary Manufacturer: Hewlett-Packard
    Serial Number: ?
    Chemistry:Lion
    Long Term: 1
    Design Capacity: 73440
    Last Full Charge: 69926
    Design capacity tells you the full capacity of your battery in milliampere-hours (mAh). Last full charge shows the mAh after last time it was full charged. These figures above tell me for example that my battery has 95% of it's desiged capacity which means it is still quite OK.
    Kari
  2. Posts : 8,476
    Windows® 8 Pro (64-bit)
  3. Posts : 8,476
    BTW, Kari could you please tell me what do these figures mean?
    Battery:Battery Information
    Battery ID Hewlett-PackardPrimary
    Manufacturer Hewlett-Packard
    Serial Number
    Chemistry Lion
    Long Term 1
    Design Capacity 4752
    Last Full Charge 4752
  4. Posts : 285
    nice to know ;-)
    Thanks!
  5. Posts : 17,545
    Sorry, Brink. Was so keen to tell about this I forgot the main rule before posting; I did not search the forums to see if this was already told.
    Serial Number
    Chemistry Lion
    Long Term 1
    It means your battery is in mint condition. I'm just surprised how low mAh it has as designed capacity.
    Kari
  6. Posts : 8,476
    Serial Number
    Chemistry Lion
    Long Term 1
    Kari
    Even I was surprised about the Design capacity as compared to your laptop battery.
  7. Posts : 17,545
    Yeah, can't figure your values out. Never seen so low mAh.
  8. Posts : 8,476
    BTW, my laptop is 18 months old now. :)
  9. Bud
    How to get extended life from a laptop battery? Should you plug the AC in every chance you get? Or should I let the battery be cycled down and then re-charge it? Mine is a new HP laptop.
  10. Posts : 17,545
    I connect my HP laptops (Pavilion and HDX series) always to mains if available. If I know I'm not going to need battery in a few days, I normally take it out when it is first fully charged.
    This trick gives some 20-30 extra minutes because it cools the laptop down so it does not need so much energy for the fan.
    Kari
