Help Me Pleaseee :(:(:(
  1. Posts : 14
    Windows7 Ultimate 32 bit and Windows XP SP2
    i have a other soundcard of pc and i need for driver for windows 7 ultimate 32 bit
    the driver webpage is MS-Tech Europa GmbH | Download
    but in this page not soundcard driver for windows 7
    help mee pleaseee
  2. Posts : 627
    win 7 ( 64 bit)
    try the vista one that should work.
  3. Posts : 14
    I tried vista but the same problem
  4. Posts : 11,840
    64-bit Windows 8.1 Pro
    Use the vista driver if they have one and you should be OK...
    Be sure to install it in Compatibility Mode..
    How to Run a Program in Compatibility Mode in Windows 7
  5. Posts : 14
    can you speak albanian beacues i cant speak good english :$
    shofer pėrdorin pėr Windows Vista
  7. Posts : 14
    I tried the vista of the three methods is the same problem again :s
  8. Posts : 11,840
    Can you use the on-board sound?? if not, then you may need to replace the card with one that is compatible with windows 7.;
  9. Posts : 14
    but i just thought how I bought not there any solution: S
  10. Posts : 11,840
    Sorry, thats the best advice I can give you...
