Sound Scheme Changes
  1. Posts : 25
    Windows 7 Pro
    Running Windows 7 Pro I have created a sound scheme, named it and saved it. However, after every 2 or 3 boot-ups it reverts to the Windows Default scheme. How do I keep my scheme constant without Windows Default taking over? Thanks.
  2. Posts : 12,120
    Win 7 Pro x64 / Win 10 Pro
    Did you save the theme to?
    Theme - Change or Save
    Jerry
  3. Posts : 25
    Windows 7 Pro
    After naming my scheme I clicked on "Save As". When it reverts to Windows Default I just go into SOUND and click my choice, apply and OK. It just doesn't stay that way.
  4. Posts : 72,058
    Hello Indian,
    Yes, you saved your Sound scheme in Sounds, but did you also save your Theme afterwards in Personalization as Jerry had linked to in his post above?
  5. Posts : 25
    Windows 7 Pro
    Thanks Brink. I have my scheme saved both in sound and persomnalization. I hope this keeps the scheme in place. Might I ask that you look at a previous post of mine under Customization, Unable to change Wecome Screen Photo/Icon. Possibly you could solve this problem for me. Thanks.
  6. Posts : 72,058
    You're welcome Indian. I hope so as well. :)
  7. Posts : 25
    Windows 7 Pro
    Hey Brink, I notice that when I'm on the Personalization screen and change the desktop background the sound scheme reverts to Windows Default. At least I know what is causing the change.
