No sound from media files after 'IObit' system improvement software
Page 2 of 2 FirstFirst 12
  1. Posts : 6,458
    Thanks, this will take a while - there are a lot of changes. Providing as much information as possible is always good - thanks for the notation on Windows Update.
    I'll try to compare the two files to see where a change might be affecting your machine. Bear in mind that I'm helping other members and also playing with Win10.
    I'll post my findings when I have any. Do NOT apply the rescue just yet.
    Another member might drop in and give you some other things to try - who knows, they might provide a solution while I'm reading the stuff you posted.
    I'll catch up on posts the next time I get back to your thread.
    Bill
  2. Posts : 6,458
       #12
    Lots of keys, nothing jumped out that would cause the issue - I did not look up all of the GUI strings though.
    Turn on System Protection
    - right click Computer,
    select System Protection,
    select the C: drive and
    press the [Configure] button
    turn on system protection and
    -set Disk space usage to about 10% of your disk.
    press [Ok]
    press the [Create] button
    Then go ahead and use the iobit utility to restore the rescue registry.
    Restart your machine
    -> Does sound work?
  3. Naj
    Windows 7 Professional x64
    Unfortunately no. No improvement or any change for that matter.
  4. Posts : 8,135
       #14
    Sadly, it may be as I suspected in the beginning.
  5. Posts : 25,847
       #15
    I have found once IObit has been chewing on you system a Clean Install is the only answer.
    If one tries to fix problems as they arise you will be forever.
    Tutorial by Brink:
    Clean Install Windows 7
  6. Posts : 6,458
       #16
    Ok....next steps
    • Manually run Windows Update
      Select all items offered, including any in the optional section
      download an install the updates
    • Restart the machine in case any operations are pending
    • Follow the instructions in:
      Windows Update Posting Instructions
      -> Ignore the title and references to Windows Update, these utilities are also useful for other issues.
      Read Step 4 carefully, many people misunderstand that they need to attach the entire CBS folder in a compressed folder (zip). If it's too large for the forum, just attach the entire CBS.log
      Skip Step 5 - that's a generic step more for people who jump in another thread and start posting the issue on their machine. It gets confusing - step 5 asks them to start a thread of their own.
      This is your thread - you want to post the output here - no need to start a new one.
    Bill
  7. Naj
       #17
    • CBS files in the attachment.
    • I've installed all available updates.
    • SFC Scan didn't find anything.
