Help with static sound
  1. Posts : 106
    Windows 7 64 Bit
    i have a 5.1 surround sound system and for some reason all the sound coming out of the speakers is mixed in with static noise.
    recently i completely formatted my hard drive (you can check the link here)
    i reinstalled my sound driver (Realtek) but i still have the same issue. any help?
    my sound system is the x-540 logitech
  2. Posts : 28,845
    Win 8 Release candidate 8400
    Is the driver installed correctly and working in device manager? Is it listed? does it have a yellow triangle on it?
    Have yoou tried different cables?
    Made sure everything is tight and not frayed?
    etc
    Ken
  3. Posts : 106
    Windows 7 64 Bit
    i wish it was that simple.
    ive already went through all these steps before i posted on here. also ive tried using different speakers.
    so far nothing different
  4. Posts : 106
    Windows 7 64 Bit
    heres some more info: when i change the quality of the sound (in the sound options) the static/cracking sound changes slightly. more drastic change between the highest and lowest quality.
    i dont know if that helps, but thats what i notice
  5. Posts : 106
    Windows 7 64 Bit
    alright guys i FINALLY GOT A SOLUTION.
    i emailed realtek and they sent me a beta driver to install. i guess the problem was:
    The root cause problem was SiS chipset on the computer . The SiS chipset has some audio problem in Windows 7 .
