Page 57 of 99 FirstFirst ... 47555657585967 ... LastLast
  1. Posts : 72,058
       #560
    stasioau said:
    Hi, I am sorry of my primitive question.
    After run "sfc /scannow" have problem with my "Window Colorization". Does not work what kind of Aero Themes I can choose. Always I get typical Window Color and Appearance not list of colors.
    Will appreciate help.
    Hello Stasioau,
    What edition of Windows 7 do you have installed?
    Did you modify any system files for the theme you had before running SFC?
  2. Posts : 103
    Hi Brink,
    Thank you so much for your answer.
    I do have Windows 7, 64-bit operating system, RAM = 16GB
    I do not modify any system for theme before SFC.
    With my best regards,
    stasioau
  3. Posts : 72,058
       #562
    For edition, would that be say Windows 7 Starter, Home Basic, Home Premium, Ultimate, etc.....? :)
  4. Posts : 103
    For edition it is Windows 7, Ultimate
    Regards
  5. Posts : 72,058
       #564
    Ok, for now, double check to make sure that you have the latest video driver installed, and see if updating your WEI score may help.
    If that doesn't help, then check the items in the red warning box at the top of the tutorial below to see if one of them may be the issue. Is still not, then please go ahead and post a screenshot of what you are seeing to see if it may help to ID the issue. :)
  6. Posts : 103
    Thanks so much Brink.
    Your ideas will be working.
    Best regards
    stasioau
  7. Posts : 72,058
       #566
    You're most welcome. :)
  8. Posts : 103
    With "Window Color and Appearance - Change" do not solve my question.
    "Screenshot" gave me some ideas and colors to my computer come back.
    Thanks Brink very much.
    Best regards
    stasioau
  9. Posts : 72,058
       #568
    I'm happy to hear that you got it sorted. What turned out to be the issue?
  10. Posts : 54
       #569
    SFC and Installer fixed!!
    Wow! you just read my mind. Now I have to fix CHK disc in Read mode. Where is 64 bit System Update
    Readiness Tool? SFC had no errors. You give great help as always!! BEST forum on the internet!
    Avie
    ps Someone logged 16 hours ago as me. There is a return private message for "me". I have not been on for many moons.
