How to Create a "Administrative Tools" Shortcut in Windows 7
This will show you how to create or download a Windows 7 Administrative Tools shortcut.
Tip
If you would like to
pin a folder to the taskbar to have Administrative Tools expand on the taskbar instead, then you can pin this folder below to the taskbar:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
EXAMPLE: Administrative Tools
NOTE: What shortcuts you have available in Administrative Tools will vary depending on what Windows 7 edition you have installed.
OPTION ONE
To Download the "Administrative Tools" Shortcut
1. Click on the download button below to download the file below.
Administrative_Tools.zip
2. Click on Save, and save the .zip file to the desktop.
3. Open the .zip file and extract the Administrative Tools shortcut to the desktop
4. Right click on the
Administrative Tools shortcut, and click on
Properties,
General tab, and on the
Unblock button. (See screenshot below)
5. You can now
Pin to Taskbar or
Pin to Start Menu this shortcut,
assign a keyboard shortcut to it, or move it where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
Option Two
To Manually Create the "Administrative Tools" Shortcut
1. Right click on a empty area on desktop, and click on
New and
Shortcut.
2. Copy and past either location below into the location area, and click on the
Next button. (see screenshot below)
%windir%\explorer.exe shell:::{D20EA4E1-3957-11d2-A40B-0C5020524153}
OR
%windir%\system32\control.exe /name Microsoft.AdministrativeTools
3. Type
Administrative Tools for the name, and click on the
Finish button. (see screenshot below)
4. Right click on the new
Administrative Tools shortcut on the Desktop and click on
Properties.
5. Click on the
Shortcut tab, then click on the
Change Icon button. (see screenshot below)
6. In the line under "Look for icons in this file", copy and paste the location below and press
Enter. (see screenshot below)
%windir%\System32\imageres.dll
7. Select the icon highlighted in blue above and click on
OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click on
OK. (See screenshot below)
9. You can now
Pin to Taskbar or
