SF IE Restorator - Troubleshooting General Issues with IE
    SF IE Restorator - Troubleshooting General Issues with Internet Explorer
    This is small utility for Troubleshooting Internet Explorer issues. It will Flush DNS, Re-register concern dlls for Internet Explorer (3 different types 64-Bit, 32 Bit on 64-Bit OS and 32-Bit) Reset IE to Default settings, Reset Winsock.
    SF IE Restorator will work with Internet Explorer in Windows 7. It will work with other operating system only if you have .NET Frameworks 3.5 installed.
       Warning
    Some Antivirus / Firewall might detect SF IE Restorator Tool is Trojan its just a False positive because the publisher is unknown. Nothing to worry it won't harm your Computer
    Screenshot
    Note: Make sure when you open the application your Right Click on the icon and click Run as administrator.
    Flush / Review DNS IP:
    Most DNS clients cache the results of name resolution requests. This means that the DNS clients will temporarily store the website names that you have been visiting lately. This process speeds up name resolution if multiple lookups are done to the same address, such as is common when browsing the web. Hence, if you visit Yahoo.com second time, the DNS client will already have the name mapped and hence will retrieve the mapping quickly. Sometimes a bad DNS entry will be cached and you will need to either flush the DNS cache to get rid of it.
    Re-register IE: There are collections of routines that are stored until a program uses them. If these files are corrupt or out of date, they can cause problems with your computer. To fix this problem, re-register the .dll files.
    Reset IE: If the problem is caused by damaged or incompatible Internet Explorer settings or add-ons, you can usually resolve the problem by resetting Internet Explorer settings.
    Reset Winsock: Most of the Internet connectivity problems arise out of corrupt Winsock settings. Windows sockets settings may get corrupted due to the installation of a networking software, or perhaps due to Malware infestation. You will be able connect to the Internet, but the packets won't transfer back and forth. Resetting Winsock might fix the issue.
    WARNING: Before running the Reset Winsock make sure you close all applications first since it will restart the computer.
    Download the application:
    Download
    Captain
  1. Posts : 17,322
    Win 10 Pro x64
    Nice work Capt.
  2. Posts : 4,772
    derekimo said:
    Nice work Capt.
    Thank You Derek !
  3. Posts : 53,365
    Windows 10 Home x64
    Had it on my PC since I tested it. Well done Capt.
    A Guy
  4. Posts : 1,020
    Windows 7 Ultimate 64 bit
    Nice work Capt!
  5. Posts : 4,772
    TimStitt said:
    Nice work Capt!
    Thanks Timo !!
  6. Posts : 4,772
    A Guy
    Thanks A Guy ! :)
  7. Posts : 12,177
    Nice tut and tool, thanks Capt, :)
  8. Posts : 5,705
    Win7 x64 + x86
  9. Posts : 4,772
    Thanks John ! :)
