Windows 7 Forums Search
Windows 7 - Power Plan - Rename
Power Plan - Rename
How to Rename a Power Plan Name in Windows 7
Published by Brink
04-02-2010
Default Power Plan - Rename
information   Information
This will show you how to rename power plans (schemes) in Windows 7 to have any name you would like.
warning   Warning
You will need to be logged in as an administrator to be able to do this.
EXAMPLE: Power Plan Renamed
Here's How:
1. Open a elevated command prompt.
2. To List and See All Power Plans
NOTE: This will give you a list of all of the power plans on your computer with the name and GUID number of each power plan.
A) In the elevated command prompt, type in powercfg list and press enter. (see screenshot below)
3. In the elevated command prompt, type in the command below (in code box) for the power plan that you want to rename, and press enter.
Note   Note
  • Substitute GUID in the command below for the actual long GUID number of the power plan that you want to rename as displayed in step 2 above.
  • Substitute New Name in the command below for the new name that you want to rename the power plan within quotes.
powercfg -changename GUID "New Name"
FOR EXAMPLE: If I want to rename the power plan Custom Plan to New Custom Plan (see example screenshots at top of tutorial), then I would type in the command exactly as below and press enter.
powercfg -changename 11eb7d0f-207d-455e-b86b-f0de0122ba90 "New Custom Plan"
4. Close the elevated command prompt.
5. The power plan has now been renamed.
Administrator
Brink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond repute
Brink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond repute
Tutorial Tools
Comment
Power Plan - Rename problems?
Tutorial Tools
Similar Threads for: Power Plan - Rename
Windows 7 Tutorial Category
Power Plan - Create Shortcut to Change Power Plan Tutorials
Power Plan - Select Tutorials
New Feature In The Power Plan. General Discussion
Power plan Performance & Maintenance
Power Options/Power plan settings? Performance & Maintenance
