Help i need help with bsod blue screen problems
  1. Posts : 5
    windows 7 ultimate x64
    Hi all i hope you can help me,i have a lot of bsod blue screen error i will put them here to look at them and maybe someone can help me.thanks
  2. Posts : 1,735
    Windows 7 enterprise 64 bit, Windows 7 Pro 64 bit ,Windows 8 64bit
  3. Posts : 5
    Hy again pls help me pls dont know what to do.....here i follow the steps from tutorial of forum post files i hope this one is good!
  4. Posts : 1,735
    Sorry for the late response Been rather sick for the past few days. But I had a look through your files and if you could please do the following:
    Enable driver verifier and allow it to crash your computer, if it has not crashed within 24 hours move on to the next step:
    Driver Verifier - Enable and Disable
    Tip: If you can not boot normally into windows after enabling Driver Verifier please boot into safe mode and then disable driver verifier.
    If Driver verifier does not cause a crash after 24 hours please run memtest86+ for at least 8 passes:
    RAM - Test with Memtest86+
    Tip: Do this over night it can take a long time
