Need Help to figure out my BSOD problem.
Page 12 of 12 FirstFirst ... 2101112
  1. Posts : 11,840
    64-bit Windows 8.1 Pro
       #111
    In that case, replace/increase your RAM ....
  2. Posts : 47
    Windows 7 Ultimate x86
       #112
    It still have its Warranty, so I will just send it to be repaired and tell 'em whats wrong..
  3. Posts : 11,990
    Windows 7 Ultimate 32 bit
       #113
    emperact said:
    But, I do think it is a Memory corruption or what it is called, because it always happens when a program is heavy on my system, and I think when i use my browser and it starts taking up to much, or if I am playing a game, I get a BSOD. The acer aspire one, only have 1 GB ram.
    EDIT: And all the time, it hangs up my conversations on Skype, with a note 'Your computer is slow'
    Memory corruption can be caused by many things other than bad RAM such as drivers, incompatible software, other hardware problems, etc. sptd.sys is a prime example of a driver causing memory corruption.
    That is not a bad idea while it is still under warranty. I recommend that you follow Tew's advice and add RAM. That alone won't eliminate memory corruption; but it will speed up your system. A total of 2 megs would be a good start for your system.
  4. Posts : 47
       #114
    well, it is not possible for ME to insert new ram, without voiding the warrenty..
    I saw under a BSOD that is said something with 'mrspc.sys'
  5. Posts : 13,354
    Windows 7 Professional x64
       #115
    Just upload the new dmps. If I don't see SPTD.sys in the dump (a sure sign of Daemon Tools), then we can work on another solution.
  6. Posts : 47
       #116
    this is the latest bsod.
  7. Posts : 13,354
       #117
    Looks like a repair install is in order.
    Also do a system files check:
    JK said:
    Open an elevated command prompt and enter sfc /scannow.
    Are you using any registry cleaning programs?
    Download a copy of Memtest86 and burn the ISO to a CD using Iso Recorder or another ISO burning program. Boot from the CD, and leave it running for at least 5 or 6 passes.
    Try a hard drive test: HD Diagnostic
    Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
    Copyright (c) Microsoft Corporation. All rights reserved.
    Loading Dump File [C:\Users\Jonathan\_jcgriff2_\dbug\__Kernel__\071010-20670-01.dmp]
    Mini Kernel Dump File: Only registers and stack trace are available
    Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
    Executable search path is:
    Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 7600.16539.x86fre.win7_gdr.100226-1909
    Machine Name:
    Kernel base = 0x8183e000 PsLoadedModuleList = 0x8197d570
    Debug session time: Sat Jul 10 09:18:43.818 2010 (UTC - 4:00)
    System Uptime: 0 days 3:46:39.458
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    1: kd> !analyze -v;lmtsmn;.bugcheck;.logclose;q
    *                        Bugcheck Analysis                                    *
    REGISTRY_ERROR (51)
    Something has gone badly wrong with the registry.  If a kernel debugger
    is available, get a stack trace. It can also indicate that the registry got
    an I/O error while trying to read one of its files, so it can be caused by
    hardware problems or filesystem corruption.
    It may occur due to a failure in a refresh operation, which is used only
    in by the security system, and then only when resource limits are encountered.
    Arguments:
    Arg1: 00000001, (reserved)
    Arg2: a1265008, (reserved)
    Arg3: 00192000, depends on where Windows bugchecked, may be pointer to hive
    Arg4: 00000374, depends on where Windows bugchecked, may be return code of
        HvCheckHive if the hive is corrupt.
    Debugging Details:
    CUSTOMER_CRASH_COUNT:  1
    DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
    BUGCHECK_STR:  0x51
    PROCESS_NAME:  explorer.exe
    CURRENT_IRQL:  0
    LAST_CONTROL_TRANSFER:  from 81a73933 to 8190f574
    STACK_TEXT:
    a2119b04 81a73933 00000051 00000001 a1265008 nt!KeBugCheckEx+0x1e
    a2119b4c 81a6845f 00192000 01e92000 00000004 nt!HvpSetRangeProtection+0x40
    a2119b84 81a69f3c a1265008 000021b4 02021810 nt!HvMarkDirty+0x43b
    a2119bac 81a65823 000021b8 00000000 b449aa3c nt!HvMarkCellDirty+0x235
    a2119c58 81aa0119 8bfc7550 a2119cd0 00000001 nt!CmSetValueKey+0x6e9
    a2119d14 8187379a 00000b64 043ce868 00000000 nt!NtSetValueKey+0x32b
    a2119d14 77b964f4 00000b64 043ce868 00000000 nt!KiFastCallEntry+0x12a
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    043ce870 00000000 00000000 00000000 00000000 0x77b964f4
    STACK_COMMAND:  kb
    FOLLOWUP_IP:
    nt!HvpSetRangeProtection+40
    81a73933 cc              int     3
    SYMBOL_STACK_INDEX:  1
    SYMBOL_NAME:  nt!HvpSetRangeProtection+40
    FOLLOWUP_NAME:  MachineOwner
    MODULE_NAME: nt
    IMAGE_NAME:  ntkrnlmp.exe
    DEBUG_FLR_IMAGE_TIMESTAMP:  4b88cac3
    FAILURE_BUCKET_ID:  0x51_nt!HvpSetRangeProtection+40
    Followup: MachineOwner
    start    end        module name
    86a09000 86a51000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
    87386000 873e0000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
    8b137000 8b149000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
    86b6d000 86b76000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
    86b41000 86b4a000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
    86b4a000 86b6d000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
    8ba55000 8bb65000   athr     athr.sys     Tue Jun 09 14:04:52 2009 (4A2EA444)
    86ab0000 86abb000   BATTC    BATTC.SYS    Mon Jul 13 19:19:15 2009 (4A5BC0F3)
    872f2000 872f9000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
    8b0ae000 8b0bc000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
    86895000 8689d000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
    a1d06000 a1d1f000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
    8d6d0000 8d6ee000   cdd      cdd.dll      Mon Jul 13 21:04:18 2009 (4A5BD992)
    868df000 8698a000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
    87252000 87277000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
    8689d000 868df000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
    8b0ef000 8b0f2700   CmBatt   CmBatt.sys   Mon Jul 13 19:19:18 2009 (4A5BC0F6)
    86d8e000 86deb000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
    86aa8000 86ab0000   compbatt compbatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6)
    8b12a000 8b137000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
    8b30d000 8b31a000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
    8b032000 8b096000   csc      csc.sys      Mon Jul 13 19:15:08 2009 (4A5BBFFC)
    8b096000 8b0ae000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
    86fd4000 86fe0000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
    87241000 87252000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
    8bbec000 8bbf6000   DKbFltr  DKbFltr.sys  Wed Mar 25 23:10:12 2009 (49CAF214)
    a1f30000 a1f38f00   DKRtWrt  DKRtWrt.sys  Wed Oct 21 04:01:19 2009 (4ADEBFCF)
    8b2f4000 8b30d000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
    8b325000 8b32e000   dump_atapi dump_atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
    8b31a000 8b325000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
    8b32e000 8b33f000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
    8b33f000 8b349000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
    8b921000 8b9d8000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 20:48:33 2009 (4AC54DE1)
    8b9d8000 8ba11000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
    86baa000 86bbb000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
    86b76000 86baa000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
    86df9000 86e02000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
    8720f000 87241000   fvevol   fvevol.sys   Fri Sep 25 22:24:21 2009 (4ABD7B55)
    87149000 8717a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
    81807000 8183e000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
    8ba11000 8ba30000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
    8b275000 8b2c5000   HdAudio  HdAudio.sys  Mon Jul 13 19:51:46 2009 (4A5BC892)
    a1c81000 a1d06000   HTTP     HTTP.sys     Mon Jul 13 19:12:53 2009 (4A5BBF75)
    87207000 8720f000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
    8bbd4000 8bbec000   i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
    8b424000 8b921000   igdkmd32 igdkmd32.sys Tue Jun 16 14:28:17 2009 (4A37E441)
    86b16000 86b1d000   intelide intelide.sys Mon Jul 13 19:11:19 2009 (4A5BBF17)
    8b0dd000 8b0ef000   intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
    8b400000 8b40d000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
    816c4000 816cc000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
    8b1de000 8b212000   ks       ks.sys       Mon Jul 13 19:45:13 2009 (4A5BC709)
    86d7b000 86d8e000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
    86ef7000 86f1c000   ksecpkg  ksecpkg.sys  Thu Dec 10 23:04:22 2009 (4B21C4C6)
    8b3c4000 8b3d4000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
    8b38f000 8b3aa000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
    8680c000 86884000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:06:41 2009 (4A5BDA21)
    8b349000 8b354000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
    8b40f000 8b41c000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
    86b2b000 86b41000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
    872c8000 872eb000   MpFilter MpFilter.sys Sat Mar 20 00:03:26 2010 (4BA4490E)
    a1f27000 a1f2fe00   MpNWMon  MpNWMon.sys  Sat Mar 20 00:03:24 2010 (4BA4490C)
    a1d1f000 a1d31000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
    a1d31000 a1d54000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:32:02 2010 (4B88CA72)
    a1d54000 a1d8f000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:32:21 2010 (4B88CA85)
    a1d8f000 a1daa000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:32:11 2010 (4B88CA7B)
    8734b000 87356000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
    86a5a000 86a62000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
    86d50000 86d7b000   msrpc    msrpc.sys    unavailable (00000000)
    86fca000 86fd4000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
    871f7000 87207000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
    86e02000 86eb9000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
    8b161000 8b16c000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
    a1c5e000 a1c6e000   ndisuio  ndisuio.sys  Mon Jul 13 19:53:51 2009 (4A5BC90F)
    8b16c000 8b18e000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
    8b264000 8b275000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
    86f4e000 86f5c000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
    86f1c000 86f4e000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
    86eb9000 86ef7000   NETIO    NETIO.SYS    Mon Jul 13 19:12:35 2009 (4A5BBF63)
    87356000 87364000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
    86fc0000 86fca000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
    8183e000 81c3e000   nt       ntkrnlmp.exe Sat Feb 27 02:33:23 2010 (4B88CAC3)
    86c21000 86d50000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
    872eb000 872f2000   Null     Null.SYS     unavailable (00000000)
    a1c18000 a1c5e000   nwifi    nwifi.sys    Mon Jul 13 19:51:59 2009 (4A5BC89F)
    872a9000 872c8000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
    86a97000 86aa8000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
    86a6d000 86a97000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
    86b1d000 86b2b000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
    86deb000 86df9000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
    a1dc2000 a1e59000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
    8b2c5000 8b2f4000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
    86884000 86895000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
    8b149000 8b161000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
    8b18e000 8b1a6000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
    8b1a6000 8b1bd000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
    8b1bd000 8b1d4000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
    86f7f000 86fc0000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
    8b1d4000 8b1de000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
    87333000 8733b000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
    8733b000 87343000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
    87343000 8734b000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
    871ca000 871f7000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
    a1c6e000 a1c81000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
    8ba30000 8ba55000   Rt86win7 Rt86win7.sys Thu Feb 26 04:04:22 2009 (49A65B16)
    871c2000 871ca000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
    a1ed6000 a1f27000   srv      srv.sys      Tue Dec 08 03:05:37 2009 (4B1E08D1)
    a1e87000 a1ed6000   srv2     srv2.sys     Mon Jul 13 19:14:52 2009 (4A5BBFEC)
    a1e59000 a1e7a000   srvnet   srvnet.sys   Tue Dec 08 03:05:06 2009 (4B1E08B2)
    8b41c000 8b41d380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
    8b0f3000 8b129400   SynTP    SynTP.sys    Thu Sep 03 20:32:25 2009 (4AA06019)
    87000000 87149000   tcpip    tcpip.sys    Mon Jul 13 19:13:18 2009 (4A5BBF8E)
    a1e7a000 a1e87000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
    8737b000 87386000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
    87364000 8737b000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
    86f6f000 86f7f000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
    8d6a0000 8d6a9000   TSDDD    TSDDD.dll    unavailable (00000000)
    8b0bc000 8b0dd000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
    8b212000 8b220000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
    8b354000 8b36b000   usbccgp  usbccgp.sys  Mon Jul 13 19:51:31 2009 (4A5BC883)
    8b40d000 8b40e700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
    8bbc5000 8bbd4000   usbehci  usbehci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
    8b220000 8b264000   usbhub   usbhub.sys   Mon Jul 13 19:52:06 2009 (4A5BC8A6)
    8bb7a000 8bbc5000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
    8bb6f000 8bb7a000   usbuhci  usbuhci.sys  Mon Jul 13 19:51:10 2009 (4A5BC86E)
    8b36b000 8b38eb00   usbvideo usbvideo.sys Mon Jul 13 19:51:51 2009 (4A5BC897)
    86a62000 86a6d000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
    872f9000 87305000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
    87305000 87326000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
    8717a000 87183000   vmstorfl vmstorfl.sys unavailable (00000000)
    86abb000 86acb000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
    86acb000 86b16000   volmgrx  volmgrx.sys  unavailable (00000000)
    87183000 871c2000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
    8bb65000 8bb6f000   vwifibus vwifibus.sys Mon Jul 13 19:52:02 2009 (4A5BC8A2)
    873e7000 873f8000   vwififlt vwififlt.sys Mon Jul 13 19:52:03 2009 (4A5BC8A3)
    86f5c000 86f6f000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
    87326000 87333000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
    8698a000 869fb000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
    869fb000 86a09000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
    873e0000 873e7000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
    8d440000 8d68a000   win32k   win32k.sys   Sat May 01 10:49:02 2010 (4BDC3F5E)
    8bbf6000 8bbff000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:19:16 2009 (4A5BC0F4)
    86a51000 86a5a000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
    8b3aa000 8b3c4000   WudfPf   WudfPf.sys   Mon Jul 13 19:50:13 2009 (4A5BC835)
    Unloaded modules:
    a1f3b000 a1f3d000   MSPCLOCK.sys
        Timestamp: unavailable (00000000)
        Checksum:  00000000
        ImageSize:  00002000
    a1f39000 a1f3b000   MSPQM.sys
        Checksum:  00000000
        ImageSize:  00002000
    a1daa000 a1dc2000   parport.sys
        Checksum:  00000000
        ImageSize:  00018000
    87277000 87284000   crashdmp.sys
        Checksum:  00000000
        ImageSize:  0000D000
    87284000 8728f000   dump_ataport
        Checksum:  00000000
        ImageSize:  0000B000
    8728f000 87298000   dump_atapi.s
        Checksum:  00000000
        ImageSize:  00009000
    87298000 872a9000   dump_dumpfve
        Checksum:  00000000
        ImageSize:  00011000
    872a9000 872c8000   cdrom.sys
        Checksum:  00000000
        ImageSize:  0001F000
    Bugcheck code 00000051
  8. Posts : 47
       #118
    Hi guys! I am sorry, for not writing back, I just havent had the time. But I got this fixed, I reinstalled XP, and now I haven't had a single crash in a week! But thanks for all your help!
    -You can mark this as solved, Thank you.
    OFFTOPIC -
    my stationary PC, is having a weird problem.hosting a game, like Counter strike Source, it crashes, but before it crash, there can pass quite some time.. Sometimes by broadcasting to justin.tv with FLME (Flash Live Media Encoder) it crashes 3-5 seconds after. It is like, it crashes when much Internet upload, is being used, or much CPU, GPU or RAM is used. By crashing i mean it says like a 'drrrrrrrrrrrrrrrrrrr' sound, and i have to hard reboot. So it doesn't leave any dump files.
  9. Posts : 11,990
       #119
    Thank you for reporting back. That is certainly a solution. :)
