Library will not accept folder on flash drive
  1. Posts : 1
    Win 7 32 bit
    When I try to include a folder on USB flash drive, I get message "This folder cannot be included because it is on a removable device
    Link "Which locations can be included states for USB drives"
    Only if the device appears in the navigation pane, under Computer, in the Hard Disk Drives section. This is set by the device manufacturer, and in some cases, it can be changed. Contact your manufacturer for more information.
    I contacted 2 Manuufacturer but do not understand problem/not able to advise which of their products will appear in HDD section
    Is there a way to
    1. make removable device appear in HDD section
    2. include folder in libraries which are on removable USB flash drive
    James
  2. Posts : 1,180
    Windows 7 Ultimate
    I found this link which shows how to Add folders to libraries and mentions USB flash drives
