#21
YAY. You have no idea how happy I am now.
Thanks a lot.![]()
Thanks a lot.![]()
I am having the same problem as described here... I have actually been on with MS support and just escalated it to level 2.. these guys have tried everything... has anhone seen how to fix this yet? This problem happened right after SP1 was applied to my win 64 system.....Everything I see in this thread has been done but no resolution
Welcome to Seven Forums valentrick. Suggest you create a new user account and see if you have the same problem there. If you do not, you can transfer your user files to the new account and use that one instead. A Guy
Dunno if this helps anybody with this problem, but when I had this exact problem, I did a repair install of Windows 7. The last thing the install did was inform me that the .Net Framework 4 needed repairing. Once the repair completed and the computer rebooted, all my gadgets worked fine. Don't know if it was the re-install or the repair that fixed it.
Hope this helps.
HairyAl
