[HELP] "No Audio Output Device is Installed"
Page 1 of 9 123 ... LastLast
  1. Posts : 44
    Good day guys, can you please help me with this,
    Problem:
    I've done so far. searching for the right driver for the audio/sounds in my laptop, but it doesn't work, and at "device manager", the "sound" thing is not there, how can i fix this problem?
    looking forward for you guys...Thanks in advance
    System Info:
    HP Pavilion dv9700 Notebook PC
    Windows 7 Ultimate
    64-bit OS
  2. Posts : 21,004
    Hello Think try this mate I personally don't like the Windows driver search and prefer the manufacturers support for drivers etc
    http://h20000.www2.hp.com/bizsupport...tem=ob-59516-1
  3. Posts : 44
    thanks for the response sir, but i've already try that one...and nothings change...hope someone can help me
  4. Posts : 21,004
    Well don't get despondent try these first
    https://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
    and https://www.sevenforums.com/tutorials/433-disk-check.html
    depending on the size of the hard drive it can take a few minutes say for a SSD and maybe up to an hour for a 500GB spinner. Some idea of what you have on the ,machine would help too cos if you have been using those tune up apps that promise you a real quick machine for instance it can really mess up the computer.
  5. Posts : 44
    thanks again sir for your patience and response, but i have already tried it before...what else i can do, should i go and reformat it?...
  6. Posts : 21,004
    Well I guess if you haven't got lot of data on the machine a clean install may solve the problem - back up[ what you want to save first image or something like that then use the clean install instead of the factory default method that way you will get a crapware free machine no HP bloatware on it.
    USB Windows 7 Installation Key Drive - Create just get the activation cod from the sticker on the machine to activate once you have installed from the stick or DVD which ever you like. Just make sure you pick the right version from the list of ISO's ones with an N alongside means that there is no Windows Media Player included for example if unsure ask.
  7. Posts : 44
    clearn install, that sounds better, i have my installation disk(Windows 7 Ultimate 64-bit), but one thing i want to ask, i dont have the cd for mobo, is it possible to download it?, TIA
  8. Posts : 21,004
    if I am not sadly mistaken Think that HP CD would have the HP bloatware on it and you should not need it and drivers get from the HP site HP Pavilion dv9700 Entertainment Notebook PC series - Download drivers and software - HP Business Support Center
    All you need to do is pick the OS and the language mate.
  9. Posts : 44
    ICit2lol said:
    if I am not sadly mistaken Think that HP CD would have the HP bloatware on it and you should not need it and drivers get from the HP site HP Pavilion dv9700 Entertainment Notebook PC series*-* Download drivers and software - HP Business Support Center
    thanks for the link sir, but all in the list are Vista, is there any Windows 7 ultimate?, i've been searching all over the internet, for the mobo driver, but no luck...
  10. Posts : 21,004
    Don't get despondent again try this and scan for Software & Driver Downloads HP Pavilion dv9700 CTO Entertainment Notebook PC | HP® Support
    in the meantime I am going to have another search:)
    John
