Help with the folder problem
  1. Posts : 33
    I don't know what happened but it seems like after i followed the guys advice on how to fix my desktop icons, this thing happened overnight after i turned the computer on. Is there anyway i can fix this back to normal? I already did the system restore and it's still the same.
    Attached Thumbnails Attached Thumbnails Help with the folder problem-icon-probs.png
  2. Posts : 6,292
    Did you try this: Icon Cache - Rebuild as Rich said in the other post?
  3. Posts : 33
    Nope. I didn't work. Thanks anyway.
  4. ryo
    windows 7
    try to SFC /SCANNOW Command - System File Checker
    after that restart your computer.
  5. Posts : 33
    Thanks a lot but it didn't change it.
