Marked wrong drive as active need help
  1. Posts : 5
    Windows 7 64bit
    So I did something really stupid and believe when I was looking around that I marked both drives as active and it moved my secondary drive to the front in the space as disk 0 and moved the windows drive to disk 1 and thanks it is supposed to boot from the wrong drive. I have no windows 7 recovery disk at hand. So when it tries to boot it says something along the lines of can't find BOOTMGR.
    What do I need to do to get my system up and running, and how do I unmark the drive as active? Please I appreciate any help.
  2. Posts : 12,012
    You can mark a partition as inactive using the diskpart command.
    If you can't boot, you should be able to access diskpart using your Windows installation disc. You just need to get to a command prompt to run it.
  3. Posts : 11,408
    ME/XP/Vista/Win7
    Physically disconnect the secondary HD.
    Make the Windows 7 HD, disk0 & first HD boot in BIOS.Also connected to the first Sata port on the MOBO.
    You may need to do a startup repair:
    Startup Repair
    Note: You may need to do startup repair 3 to 4 times.
    Startup Repair - Run 3 Separate Times
    When Windows is booting OK, Reconnect the other secondary HD, as Disk1.
    If you have not made your Startup Repair
    System Repair Disc - Create
    Do you have a mate with Windows 7 of the same bit version 32 or 64 & CD/DVD RW Drive, how could burn one off.
  4. Posts : 5
    Windows 7 64bit
    The problem with that is that I have no cd. is there like a bootdisk that I can download and put on a cd?
  5. Posts : 11,408
    ME/XP/Vista/Win7
    Do the first part than post back.
  6. Posts : 5
    Windows 7 64bit
    I removed the other drive and every timeit starts it still says bootmgr missing
  7. Posts : 11,408
    ME/XP/Vista/Win7
  8. Posts : 5
    Windows 7 64bit
    Ill see what they have. On deployment so makes it harder to find things...lol
  9. Posts : 11,408
    ME/XP/Vista/Win7
    What do you mean by deployment?
    Windows 8.
    If yes, take a look at:
    http://www.eightforums.com/tutorials...ndows-8-a.html
  10. Posts : 5
    Windows 7 64bit
    I am military and on deployment.
    I got the system up and running, and did a system restore. The secondary is still in the spot as disk 0 and marked as active. How do I get it moved back to disk 1 and marked inactive
