Backlight not working on replacement LED Screen Toshiba Portege z835
Page 3 of 3 FirstFirst 123
  1. Posts : 6,292
       #21
    There is no quick fix that I would recommend.
    Just this:
    as a guide to replacement of the fuse.
  2. Posts : 3
    7 home 32 bit
       #22
    I have a very similar problem, the only difference being that the backlight does come on for a short amount of time (until the end of the windows initialising screen) which makes me think that it is not the fuse/cb which is the problem. Is there anything else, maybe driver problems, that could cause this?
  3. Posts : 6,292
       #23
    It sounds like it is the graphics driver that initializes in Windows.
    Can you go into the BIOS settings? This would be to see if the screen stays on for a while. It will determine that it is definitely a problem in Windows.
