Secondary Seagate Hard drive disappears after making spinning sound
  1. Posts : 3,904
    Windows 7 Ultimate 64-bit
    Sorry to hear that
  2. Posts : 29
       #12
    Ok its a Seagate Barracuda 1000gb hard drive and the serial no is Z1D6CK4G
  3. Posts : 29
    going to flash my bios now wish me luck
  4. Posts : 3,904
       #14
    Good luck buddy, im just looking into your harddrive now
  5. Posts : 29
       #15
    Ok flashed my bios cant tell yet if it worked will check and let you know thanks for all the help so far have another problem now but have to open a new thread cos its not related to the hard drive issue
  6. Posts : 3,904
       #16
    Okay, Post the link il go over and take a look for you :)
    Download this and perform a scan, it should be able to help you trouble shoot from there.
  7. Posts : 29
       #17
    havent posted the tread yet still trying to look if i cant find the problem myself but thanks I cant see the link i must download though
  8. Posts : 3,904
       #18
    Sorry i forgot about the link : SeaTools for Windows | Seagate
    Give me a clue on the other problem
  9. Posts : 29
       #19
    I have already ran sea tools for windows and in dos both results tested the drive is fine that's what i cant understand but i haven't lost my drive since thew bios flash so i hoping that solved the issue the other problem im having is graphics related im testing my gpu now or it could be my monitor
  10. Posts : 3,904
       #20
    OKay its possible the BIOS update solved the problem.
    In regards to your GFX Driver.
    Run Driver Verified, and it should result in a BSOD of which i will be able to tell you about your graphics driver.
    Driver Verifier runs in the background, "testing" drivers for bugs. If it finds one, a Blue Screen of Death (BSOD) will result; the corresponding dump file will hopefully show the faulty driver.
    Driver Verifier - Enable and Disable
