Laptop Fan Problem
  1. Posts : 2
    Windows 7 professional x64 + SP1
    Laptop Fan Problem
    I have a Toshiba L50-A-104. And i think i have a problem with the fan. When i am on charge it works, when i am on battery it dont. All the interior is clean and thermal paste is new. The both (battery and on charge) advanced battery/ processor colling management definitions are set to Active.
    For the record, when on charge the fan maintains the cpu temperatures at 30-40 celsius but when on battery it comes up to 60+ celsius. What could it be?
    Cheers
  2. Posts : 1,784
    Linux Mint 18.2 xfce 64-bit (VMWare host) / Windows 8.1 Pro 32-bit (VMWare guest)
    Set your power settings to "performance" rather than "power saving". If necessary, go through your power settings thoroughly and make sure that there isn't a power-saving setting which turns the fan off to conserve battery power.
    Also, maybe your fan is getting worn out or dirty and therefore drawing too much power. Perhaps it needs cleaning or replacing.
  3. Posts : 2
    Already done all that previously all the "battery" settings are iqual to "on charge" settings. could be the battery? It still last 2 hours but it on its almost half capacity about 40% wear level.
    Thanks for the reply.
