Needs advice regarding pc parts
Page 4 of 6 FirstFirst ... 23456 LastLast
  1. Posts : 2,036
    Windows 7 Professional x64
       #31
    sergiogarcia9 said:
    I will go with the 8 gb then I will buy the i5 though, as that is really my favorite CPU :)
    Good choice! Look into the new Gigabyte boards that have USB 3 and SATA 3 and 3 times the power to the USB ports! They are the latest stuff!
    http://www.newegg.com/Product/Produc...82E16813128409
  2. Posts : 4,755
       #32
    So... PSU... What should i get?
  3. Posts : 2,036
       #33
    This would be one of the best. They cost a little more but you will NEVER regret it.
    Modular....and they come in higher (and lower) wattages if you so desire.
    Newegg.com - CORSAIR CMPSU-650HX 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply - Power Supplies
  4. Posts : 4,755
       #34
    Looked at the prices for DDR3 ram... Not cheap, i will have to go with 4 GB to start with, i think
  5. Posts : 4,755
       #35
    I would have to pay like 400 USD for 8 GB DDR3 Ram
  6. Posts : 2,036
       #36
    4 GB is a good start. I went with 8 GB and ended up moving back to 4 GB because I was no coming close to using even 4 GB.
    Look around at the prices. DDR2 WAS a lot cheaper 5-6 months ago, but today they are very close and you're getting quite a bit more speed and efficiency.
  7. Posts : 4,755
       #37
    NZXT Tempest Midi Tower Black
    Corsair TW3X4G1600C9DHX, 2x2048mb
    Intel Core i5 Lynnfield 2.66 ghz
    Intel DP55WG mATX Socket1156 NIC Bulk
    500 GB HDD
    Corsair TX650W
    Samsung 250GB SATA2 7200Rpm
    PRICE (Without DVD drive) = 865 USD (4386 DKK)
    That is a tad more expensive than i want it to be
  8. Posts : 12,012
       #38
    I don't see a video card in that list.
    Are you locked into that case? It is 110 here in the US. You can certainly knock 30 or 40 off that easily.
    Consider these, all around $60 to $70
    Antec 300; It has front and rear 120 MM fans and space for plenty of drives.
    Coolermaster Centurion 534 or Centurion 590;
    Gigabyte Triton 180
    You have modest power supply requirements--400 to 500 watts is plenty.
    These are good units and most are "80 plus certified", which is of some benefit.
    Antec Earthwatts EA500 500W Continuous Power Supply - Retail
    CORSAIR CMPSU-450VX 450W ATX12V V2.2 80 PLUS Certified Active PFC Retail
    Seasonic M12II 430 watt modular
    Seasonic SS-500ET Bronze 500W ATX12V v2.31 80 PLUS BRONZE Certified Active PFC Power Supply - OEM
    CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply - Retail
    FSP Group SAGA+ 450R 450W ATX12V Power Supply - Retail
  9. Posts : 4,755
       #39
    I think i've found it with help from DarkNovaGamer and Mr Grim
    CPU:
    AMD Phenom II X2 545 3.0GHz 80W (Box) 568,00 DKK
    Link: Proshop.dk ApS - AMD Phenom II X2 545 3.0GHz 80W (Box) - HDX545WFGIBOX - Pris DKK 568,00 - Processorer fra AMD
    Motherboard:
    ASUS M4A77TD PRO AMD770 DDR3 EPU ATX 611,00 DKK
    Link: Proshop.dk ApS - ASUS M4A77TD PRO AMD770 DDR3 EPU ATX - 90-MIB9S0-G0EAY00Z - Pris DKK 611,00 - Bundkort fra ASUS
    GFX Card:
    ASUS GeForce GTS250 - 1,0 GB GDDR3 256bit 917.00 DKK
    Proshop.dk ApS - ASUS GeForce GTS250 - 1,0 GB GDDR3 256bit - ENGTS250 DK/DI/1GD3 - Pris DKK 917,00 - Grafikkort - PCI Express fra ASUS
    RAM:
    Corsair TW3X4G1600C9DHX, 2x2048mb 705 DKK
    HDD:
    Samsung 250GB SATA2 7200Rpm 283,00 DKK
    PSU:
    Seasonic S12 II SS-500GB, 500W PSU 688.00 DKK
    Case:
    NZXT Tempest Midi Tower Black 745 DKK
    ALL TOGETHER = 4517 DKK /974 AUD / 892 USD
    At least i stayed under 1000 USD
  10. Posts : 2,036
       #40
    I would disagree with that choice or CPU and motherboard, but I suppose we all have our preferences.
    The i5 would be MUCH better.
    But it looks good, good luck on the build, you will be more than happy I'm sure.
