Wireless Network connection problem
  1. Posts : 4
    Windows 7 Professional x64
    Greetings!
    I'm here with some difficulties in connecting to my wireless network. I've formated my computer recently with a burned CD with operating system windows 7 (from uTorrent). After that, everything went wrong... The screen resolution is weird (windows and icons too big) and I can't fix it. Besides that, I can't detect any wireless networks on my computer. I think I might need to install a network device, but I'm not sure how to do it...
  2. Posts : 220
    Windows 7 Pro x64
    Have you installed the manufacturers drivers for your hardware? Sounds like you're missing video and network drivers.
  3. Posts : 4
    I'm not sure... I've formated my laptop with an OS from uTorrent.
    I can't detect any wireless network probably because I don't have the network driver installed, since I used a burned CD with the ISO file downloaded from uTorrent to format my computer. How do I re-install it (My laptop is Toshiba Satellite C660)?
    Last edited by Nickusername; 02 Dec 2012 at 12:39. Reason: My screen resolution got fixed after an update
  4. Posts : 4
    Anyone have a website where we can install network driver?
  5. Posts : 10,485
    W7 Pro SP1 64bit
    consider doing a clean install using a known good install dvd
    get your drivers from the laptop's vendor
    Toshiba Support - Homepage
