Definite!!
Possible, but not optimal. Also possible under those circumstances is the neccessity of a Repair Install
I myself believe it better to start with a clean install.
James
Highly suggest using a Corsair H50 or better yet H70 cooler and please compare with the Cool-it systems. Sealed water systems will cool well beyond any air system I'm aware of with all the risks of water removed. Then upgrade the corsair fan to two Noctura's or similar in a push pull configuration out the back of the case. Heat being the enemy of any system and for sure any OC'd system.
No. I suggest a clean install, but if not, putting the old drive with new components may require a repair install.
Also, since you are changing the motherboard, have you verified that your existing RAM will be compatible with the new board? There is a good chance that it will not be.
Again, a clean install is the best way to go if you want the best out of your new system.
James
Something you don't mention is whether you have a retail Win 7 disk or if it came with your HP Pavillion? If it came with your HP (OEM), it will not be of use on your 'new' system regardless of a clean or repair install. OEM windows are locked to the OEM equipment and will not install to a new system or new motherboard.
If indeed your windows version is OEM, you can buy the upgrade (cheaper) version of win7 only if you have a retail version of XP or Vista.
James
