4 fans, 3 normal headers + 1 "power fan" header. How to connect?
Page 3 of 3 FirstFirst 123
  1. Posts : 1,326
    Windows 10 Professional 64-bit
       #21
    You know what? I never had an aftermarket fan. Never. And, none of the boxed either from the PC or the box never broke or get noisy. Never. I won't buy anything until it happens.
  2. Posts : 11,424
    Windows 7 Ultimate 64
       #22
    I have had two fans go noisy on me. I've replaced them and also my push/pull fans on my H50 cooler with all Noctura's and the noise level and amount of air they run through the fins of the cooler is amazing. There are areas where IMO the extra cost has paid off. Take lots of pic's and post them of your build !
  3. Posts : 2,259
    W7 Professional x64
       #23
    I also demand photos
  4. Posts : 4,280
       #24
    you have received all the information you need so I'm just going to say that I think whenever possible "I think" it's a good idea to not use as many of the MB fan plugs as possible, I would rather use adapters and run them off molex connectors.
    Why? Well I have this notion that the less power you draw directly from your motherboard the better off the other hardware will be that requires being powered off the MB.
    JMO Fabe
  5. Posts : 11,990
    Windows 7 Ultimate 32 bit
       #25
    JMO Fabe
    +1 Darn good advice.
  6. Posts : 6,885
       #26
    JMO Fabe
    What I do.
    Of course, I also have my fan mod...
    ~Lordbob
  7. Posts : 11,424
       #27
    Well I feel vindicated thanks LB75 for keeping the added voltage off the mobo.
  8. Posts : 6,885
       #28
    Heh.
    I have 3 200mm fans and 1 180mm fan in my case. I always had mine plugged right into the PSU because there is not a noise issue with them (they are dead silent).
    The fan mod was a fun thing.
    ~Lordbob
  9. Posts : 1,326
       #29
    JMO Fabe
    Took in consideration. But, now, starting today, I have no more income. My last pay will be next Wednesday. And the money I have remaining will be use to be able to live. They will be connected to the motherboard for the moment.
    Btw, the build hasn't started yet. I'm waiting for my PSU, the RAM and SSD to arrive and they should on Monday. Then, I will invite my friend over to build this up~
  10. Posts : 11,424
       #30
    I'm sure it will all go swimmingly. Take pictures all along the way and the whole wire routing thing takes a ton of time but if you use your head and take your time the best routing will appear to you. I like wire ties but they are a pain to take off for a change so configure all how you like then test the computer and then cinch them down. Good chance the PSU will come with Velcro wraps that work well. If you get into a quandary then give us a post or update.
    Good Luck, the Cheese
