Help help help
  1. Posts : 75
    Windows 7 Home Premium
    Help help help
    Windows Live Messenger Error 40048820
    I have tried:
    Uninstalling msn and reinstalling
    uninstalling with revo uninstaller and perfect uninstaller.
    tried registering the .dll files.
    MY F***ING CLOCK AND TIME is right.
    i tried changing the proxy crap and internet settings relocation check server thing
    I have tried hitting my computer with a hammer causing it to freeze and having to reset it and still NOTHING
    HELP ME PLEASE i'm angry and emotional and if I had a Gundam i'm sure 1/4 of north america would have been decimated already.
  2. Posts : 13,354
    Windows 7 Professional x64
    See is there is anything in the link of use.
    Windows Live Messenger problems? Here's a fix.
  3. Posts : 75
    That isn't there. I only see
    perpassportsettings
    retailzonelevels
    retailzones
    sqm
  4. Posts : 75
    please
  5. Posts : 75
    Sigh no one anywhere on any forum will help me
  6. Posts : 13,354
    Apparently nobody here knows the answer. This is a Windows 7 forum, not an application-specific forum. True, there is a high probability someone here knows to answer to any given question, but I would recommend posting on a Microsoft forum, such as this.
  7. Posts : 11,840
    64-bit Windows 8.1 Pro
    There are other IM clients other than Messenger that you could use...
  8. Posts : 2,036
    Windows Live products have their own hidden uninstaller and repair program. I am at work or I would tell you where it's hidden, but if you browse to (Just guessing) program files / Microsoft / Windows Live / it's called Wlarp.exe. If you run this it will give you the option to fix or un-install any Windows Live program. It might work for you.
    Look for this file in the progams / Windows Live folder somewhere. If you can't find it, I will tell you where it is in about 10 hours.
  9. Posts : 75
    the Wlarp didn't work.
    the msn guys spin. and then freeze up just as it would logging me on normally then it give me the error.
  10. Posts : 2,036
    SO you tried repair and it didn't work. Well good luck. I hope someone can help.
