No sound again. Help me.
  1. Posts : 236
    Windows 7 Ultimate 32-Bit
    What happens if you go to the sound mixer and go to the levels tab?
  2. Posts : 17
    MS windows 7 home premium
       #12
    so confused on why it wont work :/ ugh
  3. Posts : 236
    did you try the sounds tab?
  4. Posts : 17
       #14
  5. Posts : 236
       #15
    ok, have you tried using headphones vs. the onboard speakers?
  6. Posts : 17
       #16
    no sounds ugh
    Look at my other thread for more info. but basically i upgraded from windows XP to windows 7, on my gateway laptop and now there is no sound. it says the its installed and everything and when i play videos and click on the sound icon the bar moves up and down like the sounds works. i tried youtube everything NO sound. it does have sound when the machine starts up though.
    just thought posting in this forum would help me get better answers.
  7. Posts : 2,963
       #17
    You said it has sound when starting up. When specifically do you hear sound from the computer?
  8. Posts : 3,139
       #18
    Download the latest sound driver for your notebook. Dunno if your gateway is 7327gz, or other letters...
    Gateway Support - 4694 Gateway 7326GZ Notebook
    Take a look at your Volume Mixer and be sure nothing is muted.
  9. Posts : 908
    Windows 7 Home Premium
       #19
    Also, right click Microsoft speaker icon in task bar, slect Playback Devices, make sure Speakers is set as your default device, select speakers and then the properties button at the lower right, if you have the Enhancements tab, select it then disable all enhancements select "Apply" and reboot.
    Ap
  10. Posts : 1
    windows 7 home premium x32
       #20
    I had the same problem with no sound on a clean install of windows 7 on a 7326gz and had all the same screens that were shown in the replys. I could see everything should be working and just couldn't hear any sound. So here's what I did:
    1. Download the xp audio driver 9528156 from Gateway Support Gateway Conexant Audio Driver Version: 6.13.10.8240 and save it to a folder or the desktop
    2. Go to where ever you saved it and double click on the zipped file. This will extract the files to C:\cabs\9528156
    3. Go to C:\cabs\9528156, right click HFXsetup and click on Run as Administrator. Clicking the Run as Administrator is the key here.
    Once I did that I restarted my laptop and got sound.
    The only thing I didn't get working as well is the video driver. My device manager still does not recognize the video controller but I'm quite happy with the default video driver that's in Windows 7.
