Realtek HD Audio No Rear Sound
  1. Posts : 5,840
    Vista Ult64, Win7600
       #21
    I
    Hi, ok I know I am always telling people to install this program
    But I think it seems to solve a lot of problems, if it finds that you
    need to update your chipset drivers, so download and install this
    program and follow the instructions, and we will see if it finds
    anything for your machine that can help.
    http://www.radarsync.com/
  2. Posts : 28,845
    Win 8 Release candidate 8400
       #22
    shaheer92 said:
    I have a problem with the Realtek HD Audio. I just installed Windows 7, and configured my audio settings for all my 4 speakers, 2 front and 2 rear. The test was successful, from Realtek HD Audio Manager.
    But I was just playing a song on iTunes and there was no sound coming from the rear speakers. I went opened the Audio manager again and checked the settings, and they were fine. I even tested all four speakers and I could hear those BEEPS or whatever from them, but the song only played through the fron speakers.
    I went through forum, and found out there's an update to the driver. I just installed it, but it got worse. It doesn't support the 4 speaker settings, all I see is a speaker setting for STEREO. What do I do now, re-install the old driver again?
    And what should I do about no sound coming from my rear speakers?
    Thanks guys, and please help! =(
    Shaheer92
    Welcome to sevenforums.
    You running 32 bit or 64?
    Ken
  3. Posts : 24
       #23
    jfar said:
    I
    Drivers Update Software by RadarSync
    I've downloaded it but I'll run it tomorrow and tell you if it worked. Thanks. =)
  4. Posts : 24
       #24
    zigzag3143 said:
    Shaheer92
    Ken
    Thanks! =)
    I am running 32 bit Windows 7.
  5. Posts : 5,840
       #25
    Ok, will see you then.
  6. Posts : 24
       #26
    Hey, I'm back.
    Ok so, I installed the software, it found an update for my Nvidia Geforce 9500 GT, and Realek. The download of 9500GT failed, and i installed the realtek driver update (it was 2.55). After the installation, the buzzing sound is back...
  7. Posts : 5,840
       #27
    Hi, in the Device manager have you any exclamation signs around any of your
    Sound devices?
  8. Posts : 24
       #28
    No man, no exclamation signs.
  9. Posts : 24
       #29
    What I don't get is that when I can hear the system sounds and the speaker test sound effects from each individual speaker, then why is the audio of songs and movies played only through the front speakers? I've tried using different players, but nothing happened.
  10. Posts : 212
    Windows 7 Ultimate x64 (Retail)
       #30
    As far as songs go, they are stereo, 2-channel. Your player would require some plugin to redirect sound to 4 speakers vs just the 2 default channels (not all channel splitters work as promised).
    As for Video files, check the filter/codec software you are using. I resolved this by using AC3 audio filter. (note there is now an x64 version of this - v1.61)
    Hope this helps you.
