System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one...
When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound.
I would like to mute the Windows 7 sound that happens when I adjust the sound, preferably without effecting the other system sounds? I can't find out which system 'event' it is that causes a sound to be generated when I modify the speaker volume. I'd like to mute it, i.e. no sound when I change the volume.
thanks
