Microphone volume won't stay put
I want to lower my microphone volume from 100 to 50. When I do it, it will stick around for a little while (while I record something), but then it will jump back to 100 sometime after I'm done or even before I start. For some reason, the adjustment just won't be saved. I'm hitting OK to close the menus, so that isn't the issue. Here is a screenshot of the menu I am using:
Capture.png picture by Wyrd5 - Photobucket
I am trying to keep the top bar at 50, but it just won't stay put. Can anyone help me? Thanks.
