No Sound From Front Headphone Jack
  1. Posts : 4
    When I first installed Windows 7 on my computer I had to manually install a sound driver. I went to the Dell site and downloaded the only audio driver for my system, Dell Precision T7500.
    The driver was SoundMax. The onboard sound worked, but the headphone socket one the front wasn't. Even when I had my headphones plugged it they werent getting picked up on Playback devices.
    A friend of mine told me to just delete the driver, and let windows download its own sound driver (it didn't do it when I installed windows for some reason). So, I rebooted after uninstalling the SoundMax driver and Windows automatically downloaded and installed the "High Definition Audio Device" driver.
    Now the audio icon in the windows tray has a red cross on and says "No speakers or headphones are plugged in" I plugged my headphones in on the fron headphone jack and its not picking them up.
    I click the icon and let it troubleshoot headphones. I get the following message "The peripheral does not appear to be plugged in. Check the connection. Proceed to next step to finish." I unplug them and plug them back in, click next, and it just says the issue is not fixed.
    I have taken the side panel off and check the connections and all wires are connected.
    dxdiag is showing as no sound card present. Results are below:
    System Information
    Time of this report: 5/28/2011, 10:50:31
           Machine name: DAMONANDHANNAH
       Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110408-1631)
               Language: English (Regional Setting: English)
    System Manufacturer: Dell Inc.
           System Model: Precision WorkStation T7500
                   BIOS: Phoenix ROM BIOS PLUS Version 1.10 A07
              Processor: Intel(R) Xeon(R) CPU           X5660  @ 2.80GHz (12 CPUs), ~2.8GHz
                 Memory: 49152MB RAM
    Available OS Memory: 49150MB RAM
              Page File: 3850MB used, 94446MB available
            Windows Dir: C:\Windows
        DirectX Version: DirectX 11
    DX Setup Parameters: Not found
       User DPI Setting: Using System DPI
     System DPI Setting: 96 DPI (100 percent)
        DWM DPI Scaling: Disabled
         DxDiag Version: 6.01.7601.17514 32bit Unicode
    DxDiag Notes
          Display Tab 1: No problems found.
            Sound Tab 1: No sound card was found.  If one is expected, you should install a sound driver provided by the hardware manufacturer.
              Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D:    0/4 (retail)
    DirectDraw:  0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay:  0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow:  0/6 (retail)
    Display Devices
              Card name: NVIDIA Quadro NVS 295
           Manufacturer: NVIDIA
              Chip type: Quadro NVS 295
               DAC type: Integrated RAMDAC
             Device Key: Enum\PCI\VEN_10DE&DEV_06FD&SUBSYS_062E10DE&REV_A1
         Display Memory: 3815 MB
       Dedicated Memory: 231 MB
          Shared Memory: 3583 MB
           Current Mode: 1680 x 1050 (32 bit) (59Hz)
           Monitor Name: ViewSonic VA2216w-4
          Monitor Model: VA2216w SERIE
             Monitor Id: VSC2920
            Native Mode: 1680 x 1050(p) (59.954Hz)
            Output Type: Displayport External
            Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
    Driver File Version: 8.17.0012.7071 (English)
         Driver Version: 8.17.12.7071
            DDI Version: 10
           Driver Model: WDDM 1.1
      Driver Attributes: Final Retail
       Driver Date/Size: 4/28/2011 06:39:04, 12936808 bytes
            WHQL Logo'd: Yes
        WHQL Date Stamp:
      Device Identifier: {D7B71E3E-45BD-11CF-F168-22261FC2C535}
              Vendor ID: 0x10DE
              Device ID: 0x06FD
              SubSys ID: 0x062E10DE
            Revision ID: 0x00A1
     Driver Strong Name: oem3.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section012:8.17.12.7071:pci\ven_10de&dev_06fd
         Rank Of Driver: 00E62001
            Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
       Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
           D3D9 Overlay: Supported
                DXVA-HD: Supported
           DDraw Status: Enabled
             D3D Status: Enabled
             AGP Status: Enabled
    Sound Devices
                Description:
     Default Sound Playback: No
     Default Voice Playback: No
                Hardware ID:
            Manufacturer ID:
                 Product ID:
                       Type:
                Driver Name:
             Driver Version:
          Driver Attributes:
                WHQL Logo'd:
              Date and Size:
                Other Files:
            Driver Provider:
             HW Accel Level: Emulation Only
                  Cap Flags: 0x0
        Min/Max Sample Rate: 0, 0
    Static/Strm HW Mix Bufs: 0, 0
     Static/Strm HW 3D Bufs: 0, 0
                  HW Memory: 0
           Voice Management: No
     EAX(tm) 2.0 Listen/Src: No, No
       I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Sound Capture Devices
    DirectInput Devices
          Device Name: Mouse
             Attached: 1
        Controller ID: n/a
    Vendor/Product ID: n/a
            FF Driver: n/a
          Device Name: Keyboard
             Attached: 1
        Controller ID: n/a
            FF Driver: n/a
    Poll w/ Interrupt: No
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x8086, 0x3A34
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    Gameport Devices
    PS/2 Devices
    + HID Keyboard Device
    | Vendor/Product ID: 0x413C, 0x2106
    | Matching Device ID: hid_device_system_keyboard
    | Service: kbdhid
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    + HID-compliant mouse
    | Vendor/Product ID: 0x046D, 0xC063
    | Matching Device ID: hid_device_system_mouse
    | Service: mouhid
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    Disk & DVD/CD-ROM Drives
          Drive: C:
     Free Space: 31.2 GB
    Total Space: 152.5 GB
    File System: NTFS
          Model: ATA WDC WD1600HLFS-7 SCSI Disk Device
          Drive: E:
     Free Space: 129.5 GB
    Total Space: 152.6 GB
    File System: NTFS
          Drive: G:
     Free Space: 727.9 GB
    Total Space: 953.2 GB
    File System: NTFS
          Model: WD My Book 1110 USB Device
          Drive: D:
          Model: PLDS DVD+-RW DH-16ABS ATA Device
         Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
          Drive: F:
          Model: WD Virtual CD 1110 USB Device
          Drive: H:
          Model: DTSoftBusCd00
    System Devices
         Name: Intel(R) ICH10 Family PCI Express Root Port 6 - 3A4A
    Device ID: PCI\VEN_8086&DEV_3A4A&SUBSYS_026D1028&REV_00\3&172E68DD&0&E5
       Driver: n/a
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
    Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_026D1028&REV_00\3&172E68DD&0&EA
       Driver: n/a
         Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
    Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_006D0028&REV_22\3&172E68DD&0&A2
       Driver: n/a
         Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
    Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_026D1028&REV_22\3&172E68DD&0&18
       Driver: n/a
         Name: NVIDIA Quadro NVS 295
    Device ID: PCI\VEN_10DE&DEV_06FD&SUBSYS_062E10DE&REV_A1\4&17EC323&0&0038
       Driver: n/a
         Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
    Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_026D1028&REV_00\3&172E68DD&0&E0
       Driver: n/a
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
    Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_026D1028&REV_00\3&172E68DD&0&E9
       Driver: n/a
    Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_22\3&2FC90B2B&0&A2
       Driver: n/a
         Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
    Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_026D1028&REV_22\3&172E68DD&0&08
       Driver: n/a
         Name: Texas Instruments 1394 OHCI Compliant Host Controller
    Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_026D1028&REV_00\4&233C1052&0&50F0
       Driver: n/a
         Name: High Definition Audio Controller
    Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_026D1028&REV_00\3&172E68DD&0&D8
       Driver: n/a
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
    Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_026D1028&REV_00\3&172E68DD&0&E8
       Driver: n/a
         Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
    Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_006D0028&REV_22\3&172E68DD&0&A1
       Driver: n/a
         Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3406
    Device ID: PCI\VEN_8086&DEV_3406&SUBSYS_026D1028&REV_22\3&172E68DD&0&00
       Driver: n/a
         Name: Dell SAS 6/iR Integrated Workstation Controller
    Device ID: PCI\VEN_1000&DEV_0058&SUBSYS_021D1028&REV_08\4&3DF0BE&0&00E0
       Driver: n/a
         Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
    Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_026D1028&REV_00\3&172E68DD&0&D7
       Driver: n/a
         Name: Intel(R) ICH10 Family SMBus Controller - 3A30
    Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_026D1028&REV_00\3&172E68DD&0&FB
       Driver: n/a
    Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_22\3&2FC90B2B&0&A1
       Driver: n/a
         Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_026D1028&REV_90\3&172E68DD&0&F0
       Driver: n/a
         Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
    Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_026D1028&REV_00\3&172E68DD&0&EF
       Driver: n/a
         Name: Intel(R) ICH10 Family 6 Port SATA AHCI Controller - 3A22
    Device ID: PCI\VEN_8086&DEV_3A22&SUBSYS_026D1028&REV_00\3&172E68DD&0&FA
       Driver: n/a
         Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 9 - 3410
    Device ID: PCI\VEN_8086&DEV_3410&SUBSYS_026D1028&REV_22\3&2FC90B2B&0&48
       Driver: n/a
         Name: Intel(R) PRO/1000 MT Server Adapter
    Device ID: PCI\VEN_8086&DEV_1026&SUBSYS_10018086&REV_04\5&A463B67&0&000008
       Driver: n/a
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
    Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_026D1028&REV_00\3&172E68DD&0&D2
       Driver: n/a
         Name: Intel(R) ICH10R LPC Interface Controller - 3A16
    Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_026D1028&REV_00\3&172E68DD&0&F8
       Driver: n/a
         Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
    Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_026D1028&REV_22\3&2FC90B2B&0&38
       Driver: n/a
         Name: Broadcom NetXtreme 57xx Gigabit Controller
    Device ID: PCI\VEN_14E4&DEV_1681&SUBSYS_026D1028&REV_10\4&351402F6&0&00E5
       Driver: n/a
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
    Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_026D1028&REV_00\3&172E68DD&0&D1
       Driver: n/a
         Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E
    Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_006D0028&REV_22\3&172E68DD&0&A0
       Driver: n/a
    Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_026D1028&REV_22\3&172E68DD&0&38
       Driver: n/a
         Name: PCI standard PCI-to-PCI bridge
    Device ID: PCI\VEN_12D8&DEV_E130&SUBSYS_00000000&REV_04\4&2F86DE32&0&0008
       Driver: n/a
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
    Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_026D1028&REV_00\3&172E68DD&0&D0
       Driver: n/a
    Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_22\3&2FC90B2B&0&A0
       Driver: n/a
    Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_026D1028&REV_22\3&2FC90B2B&0&18
       Driver: n/a
    Device ID: PCI\VEN_10DE&DEV_06FD&SUBSYS_062E10DE&REV_A1\4&26E0BFED&0&0018
       Driver: n/a
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
    WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
    Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
    WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
    WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109
    WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
    WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3508.1109
    WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
    DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
    Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17514
    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
    MainConcept AAC Decoder,0x00400000,1,1,,
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
    AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17514
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17514
    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
    "MainConcept (Adobe2) AAC Decoder",0x00600000,1,1,ad2daac.ax",
    "MainConcept (Adobe2) MPEG Splitter",0x005fffff,1,2,ad2mcspmpeg.ax",
    "MainConcept (Adobe2) MPEG Audio Decoder",0x005fffff,1,1,ad2mcdsmpeg.ax",
    "MainConcept (Adobe2) MPEG Video Decoder",0x005fffff,1,1,ad2mcdsmpeg.ax",
    "MainConcept (Adobe2) MPEG Encoder",0x00200000,2,1,ad2mcesmpeg.ax",
    "MainConcept (Adobe2) MPEG Video Encoder",0x00200000,1,1,ad2mcevmpeg.ax",
    "MainConcept (Adobe2) MPEG Audio Encoder",0x00200000,1,1,ad2mceampeg.ax",
    "MainConcept (Adobe2) MPEG Multiplexer",0x00200000,1,1,ad2mcmuxmpeg.ax",
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
    MainConcept MP4 Demultiplexer,0x00400000,1,2,,
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17514
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
    VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
    SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17514
    DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17514
    MainConcept (Consumer) AVC/H.264 Video Decoder,0x00400000,1,2,,
    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17514
    Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17514
    Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17514
    Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17514
    File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109
    VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
    File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
    "MainConcept (Adobe2) AAC Encoder",0x00100000,1,1,ad2eaac.ax",
    iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
    iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
    DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17514
    Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17514
    AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17514
    RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
    WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
    SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
    Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17514
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17514
    Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
    MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
    File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17514
    TechSmith File Source,0x00400000,0,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith SWF Writer,0x00200000,2,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith WMFSDK Writer,0x00200000,1,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Simple PIP,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426
    ImageSource,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426
    TitleSource,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Time Adjust,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Splitter Filter,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Frame Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Perf Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith ZoomPIP Filter,0x00200000,2,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith PushVMR Source,0x00200000,0,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith PushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith SimplePushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Wave Dest,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Overlay,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Wave Buffer,0x00200000,1,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith ForceColor 8,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith ForceColor 555,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith ForceColor 565,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith ForceColor 24,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith ForceColor 32,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Force Color32A,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426
    SSFileWriter,0x00200000,1,0,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Frame Rate Tuner,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Camera Adjust,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426
    Techsmith Quicktime MOV Source,0x00600000,0,2,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Sound Effects Filter,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Flv Key Frame Setter,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426
    TechSmith Floating Point Wave Filter,0x00800000,1,1,CamtasiaFilters.dll,7.00.0000.1426
    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
    StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
    AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17514
    File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17514
    File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17514
    LAME Audio Encoder,0x00100000,2,1,lame_dshow.ax,1.00.0054.50801
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17514
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17514
    "MainConcept (Adobe2) H.264/AVC Decoder",0x00600000,1,1,ad2dsh264.ax",
    "MainConcept (Adobe2) H.264 Encoder",0x00200000,2,1,ad2esh264.ax",
    "MainConcept (Adobe2) H.264/AVC Video Encoder",0x00200000,1,1,ad2evh264.ax",
    iZotope Vocal Enhancement,0x00200000,1,1,iZotope_VocalEnhancement.dll,1.00.0000.0024
    iZotope Consumer Restoration,0x00200000,1,1,iZotope_ConsumerRestoration.dll,1.00.0000.0024
    WDM Streaming Tee/Splitter Devices:
    Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17514
    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
    TechSmith Screen Capture Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
    VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.06.7601.17514
    VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
    WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
    GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17514
    Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17514
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17514
    PBDA CP Filters:
    PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
    PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
    PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
    Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17514
    BDA Network Providers:
    Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
    Multi-Instance Capable VBI Codecs:
    BDA Transport Information Renderers:
    BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17514
    MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17528
    Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17528
    PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17528
    XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17528
    WDM Streaming Communication Transforms:
    Audio Renderers:
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17514
    EVR Power Information
    Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
      Quality Flags: 2576
        Enabled:
        Force throttling
        Allow half deinterlace
        Allow scaling
        Decode Power Usage: 100
      Balanced Flags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force half deinterlace
        Force scaling
        Decode Power Usage: 50
      PowerFlags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force scaling
        Decode Power Usage: 0
    Am I downloading the wrong driver? What driver should I get?
    Any help is much appreciated :)
  2. Posts : 1,496
    7 Ultimate x64
    What sound card do you have?
  3. Posts : 4
    I am not sure. I think it is Integrated High Definition Audio (Rev 1.0 Specification) implemented with a two-chip audio solution comprised of the ADI 1984a High Definition Audio CODEC and the ICH10's integrated AC97/High Definition digital controller.
    Like I said about, my friend has the same computer and said he didn't download the SoundMAX driver from the Dell site, and let Windows 7 install the
    "High Definition Audio Device" driver. His works fine, including the front headphone jack.
    So I am confused at why mine doesn't work. I spoke to Dell support and they were USELESS.
    Back audio socket works fine, front one doesnt work. Same for the mic socket on the front. The image below shows. The back socket working, front socket not picking up anything.
  4. Posts : 1,496
    7 Ultimate x64
    You're going to have to open the case and follow the wires from the front audio jacks to the motherboard... first find out if they're even connected.
  5. Posts : 4
    OMG I cannot belive it!
    I checked the connection the other day, it was unplugged on the motherboard so i plugged it back in and it still wasnt working.
    I left it open this time and noticed that after i put it back in the wire was quite tight so it kept popping back out! I pulled it so it wasnt as tight and now it stays plugged in .... hahaha what a fool I am.
    Thanks for you help Fumz, your message made me check the connection again!
  6. Posts : 1,496
    7 Ultimate x64
    :) I do love it when the fixes go smoothly.
