Realtek HD Audio Manager Problem!
  1. Posts : 27
    So, I have Realtek HD Audio Manager installed, and the latest drivers. My sound is now working fine, but my microphone isn't even being picked up. I don't know what kind of problem this is, but I was looking for help. My motherboard with on-board sound is a ECS Elitegroup GeForce7050m-m. Thanks for the help
  2. Posts : 53,365
    Windows 10 Home x64
    Welcome to Seven Forums Glurft. If you have 2 channel sound, make sure it is set that way. Open Realtek HD Audio Manager, under the Audio I/O tab changed the 6 channel speaker settings to 2 channel. When it's set to 6 channel it uses the mic port (the pink one) as a center speaker and sub output. Also make sure if you are using the pink, back panel connector, that the disable front panel jack detection is checked. This is done through the Connector settings which is the little icon in top left hand corner of the window.
    A Guy
  3. Posts : 1
    windows7 ultimate 32bit
    i have problem with audio.
    ..i use windows7 ultimate OS when i finished installing win7 ultimate in the task bar it say's that No Audio output Device is installed i use speaker with 1 jack for green and for the plug...
    ..pls help me how to fix this problem...!
    OS: windows 7 ultimate (32bit)
  4. Posts : 53,365
    Windows 10 Home x64
    Welcome to Seven Forums rjay213. Going to ask that you start your own thread, and someone will help you fix your problem. This thread is for Glurft and his particular problem. Just click on the New Thread button in upper left, and post your question. Give us your system specs and someone will help.
    A Guy
  5. Posts : 27
    Thanks A Guy for the response, sorry I am responding late, as I had some other things to take care of. Anyway, I opened up Realtek HD Audio Manager, and I do not see an Audio I/O Tab. I don't know if I'm just being stupid, or if it really isn't there. Thanks for the help again :)
  6.   My Computer
  7. Posts : 27
    Currently, I have windows 7, and the first video you linked didn't have much help. It said to open miccal.exe under the windows folder that I do not have, and the Realtek setup for XP is a lot different than 7. The other two links talked about the 6 channel thing like you did, but I cannot find any of the stuff you or they are talking about. Another note, my mic is acting very strangely. When I unplug my headset (green port) my mic will work. When I plug it back in, the mic won't work, but sound will.
  8. Posts : 53,365
    Windows 10 Home x64
    Hoping someone using the manager will be along to assist you. In the mean time, see if the issues discussed in this thread apply:
    Realtek HD Changing Jack output reassignments ( FIX )
    A Guy
