sound problems with Realtek ALC 882 sound card
Page 1 of 3 123 LastLast
  1. Posts : 2
    Windows XP/Windows 7
    I have a HP Media Center PC. the Model number is a1412n I am dual booting xp and windows 7, and in windows 7 I am not getting any sound. When I went to check it out, I realized that the computer was only recognizing the front audio jack. So i plug my speakers into the front jack but it still says nothing is plugged in. It works fine in XP. does anyone have an Idea? I have a Realtek ALC 882 sound card.
    Thanks in advance.
  2. Posts : 4,364
    Windows 11 21H2 Current build
    Hi, xprojectd24, and welcome to the forums.
    Have you tried installing the Vista drivers from RealTek?
    See http://www.realtek.com.tw/downloads/...Audio%20Codecs
  3. Posts : 2
    the link that you directed me to would not let me download the drivers.
    I think I downloaded the drivers from another website, but I'm not sure whether I got the XP or Vista version
  4. Posts : 4,282
    Vista drivers would be your best bet as windows 7 is more Vista then it is XP
  5. Posts : 6
    windwos 7 beta
    check sound options in control panel, that's where I found my problem, working now!
  6. t2n
    Windows 7 x64
    i had a problem with ALC 882 sound card (integrated with mobo), driver was recognized by w7,but there was no sound, but i managed it with giving manually drivers from ALC880-882_Vista_V6015306.zip found on Internet (vista x64 driver for alc882) and everything works fine now :)
    edit: Realtek High Definition Audio Driver R2.14 for Vista works better.
  7. Posts : 7
    Win7 7000 x64
    I have an abit I-N37H mobo with realtek integrated sound and i have the same issue where only the front panel is recognized and no sound comes out of it. i have tried the r2.22 drivers that came out recently to no avail. i am going to try what t2n said and manually load the drivers from ALC880-882_Vista_V6015306.zip, but i don't have high hopes.
    edit: ALC880-882_Vista_V6015306.zip didn't work, and i created my own thread for my problem seeing as it is slightly different from this threads one: https://www.sevenforums.com/sound-audio/7916-realtek-only-allowing-digital-output.html
  8. t2n
    Windows 7 x64
    i'm waiting for your report about ALC880-882_Vista_V6015306.zip, abaddon3k (do not forget about checking Realtek High Definition Audio Driver R2.14 for Vista too)
    greets, t2n
  9. Posts : 7
    Win7 7000 x64
    whoops, that edit wasn't supposed to be r2.22, it was supposed to be the ALC880-882_Vista_V6015306.zip.
    the drivers i need would be in the vist64 folder right? (i am on x64)
    and i did try 2.14 as well as r1.78, r1.90, r2.16
  10. t2n
    Windows 7 x64
    could you write some details about your sound card name vendor etc ? i'll try to look for proper driver..
