Stereo Mix Problem on VAIO laptop
  1. Posts : 11
    Windows 7 Home Premium 64-bit
    Hey guys,
    I have been trying to get stereo mix working on my VAIO laptop but i have failed.
    the model is VGN-AW110N. I have windows 7 ultimate x64.
    please help me
    i have gone to the VAIO esupport website and installed the audio driver from there too, but i dont get the stereo mix option in my sound settings.
  2. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Right click on Microphone or Line In, put a check by Show Disabled Devices, and enable Stereo Mix.
    Stereo Mix Problem on VAIO laptop-capture-3.png Stereo Mix Problem on VAIO laptop-capture-4.png Stereo Mix Problem on VAIO laptop-capture-5.png
  3. Posts : 11
    i have already ticked both of them but stereo mix doesn't appear.
  4. Posts : 1,996
    Is the High Definition Audio......Realtek?
    If so, try it from here Realtek
  5. Posts : 11
    tried it, its not working :/
    its High Definition Audio Realtek btw.
  6. Posts : 5,642
    Windows 10 Pro (x64)
    Then you most likely do not have stereo mix on that hardware.
  7. Posts : 11
    so you're telling me my Realtek HD Audio hardware doesn't support stereo mix ? hows that possible :/ its an HD soundcard :/
  8. Posts : 1,996
    You may be able to get stereo mix using Realtek r.161.
    Someone reported that it works on a Vaio CW32, but there was a side effects of the speaker and headphone both working at the same time.
  9. Posts : 11
    it doesn't matter i just need to get this thing working, can you give me the link to the realtek r.161 please?
  10. Posts : 1,996
    You'll have to use the Vista driver.
    You may have to run it in compatibility mode.
    Compatibility Mode
    Download Realtek High Definition Audio 2.61 Vista 64 - Technical Details - FileHippo.com
