One of my audio devices is installed, but not listed as a default dev
  1. Posts : 129
    So, I have these wireless headphones that I got from Brookstone. The device driver is called E-Core wireless audio. Its installed and ready, but it's not listed as a default playback device in volume control. How to fix?
    It worked ok before. There's no driver to install on my wireless headphones.
  2. Posts : 129
    Apparently another device doesn't wanna show up either..
  3. Posts : 8,135
    As "another device" does not show up too this suggests some problem other than just an "audio" problem. Post back with more info about the problems and also what the status of the affected devices are in the Device Manager.
  4. Posts : 129
    Both devices are working properly.
  5. Posts : 8,135
    Connect the Devices, one at a time, and then go to the Device Manager. RIGHT click on the entry for the device and then LEFT click "uninstall". DO NOT check the box to uninstall the drivers. After both have been uninstalled, physically disconnect them from the PC then restart the PC. After Windows finishes initializing, connect one device at a time and Windows should detect and install the device. Many times this fixes problems such as yours and if you are lucky it will fix yours.
  6. Posts : 129
    Ok, i'll try that and let you know if that works out for me.
  7. Posts : 129
    hey, sorry i haven't posted back in awhile, i still haven't done this yet, i'm gonna though.
  8. Posts : 129
    I left click to uninstall, and it just says "you are about to remove the device from your system." it doesn't give me no box..
  9. Posts : 129
    one of them didn't come with any cd, so i don't think my wireless headphones matter, but i have the drivers on the other headset.
  10. Posts : 129
    restarting now.
