Latest realtek driver made my audio system sound terrible
  1. Posts : 21
    windows 7 32 bits
    Bad sound quality( after installing Realtek latest driver?)
    I just installed the latest driver and now the sound qulity is notso good as before even i ddint change anything in my realteck manger. I dont know if it counts but I my windows is installing automatically another driver HD audio device but I dont think that matter since I have that disabled and even uninstalled once just to see if affects the quality but nothing.
    here some capture
    My system specs are on the atachment
    My mothertboard specs here ASUSTeK Computer Inc. - Motherboards- ASUS P5GC-MX/1333
    Graphic card Asus 3650 512MB 725MHz EAH3650 SILENT MAGIC/HTDP/512M ATi PCI-Express 2.0 Video Card w/ Dual DVI, HDTV, HDCP, Avivo HD, DirectX 10 : EAH3650 SLNT MG/HTDP/512M (Retail) (Discontinued)
    Audio system Dove Electronics - Genius 5.1 Channel Home Theatre System - 150W
    About the sound quality I will try to make a descriprion even my english is not 100%
    its like my system is trying to reproduce an rough coarsed acousting sound and my sub sounds are distorted with a tremble. plus anoying scarts and squeakies, screechings when u play for ex a instrumental track.
    Latest realtek driver made my audio system sound terrible Attached Files
  2. Posts : 54
    Win7 Home Premium 64 bit
    Un check speaker fill, set sound effect to room, enable room correction, set the speaker distance and set the rear and sub speakers to +10 db and leave others at 0db.
  3. Posts : 10,994
    Win 7 Pro 64-bit
    Hello StefaNafetS and welcome to Seven Forums.
    Was your computer having any audio problems before you installed the updated Realtek driver? If it wasn't having any problems I'd go back to the previous driver. You can use a previously made Restore Point.
    System Restore
    Or, you can roll back the driver.
    1. Open Device Manager.
    2. Locate the device that you want to roll back the driver for (probably under sound, video and game controllers.)
    3. Right click on the device's name or icon > click on Properties.
    4. In the Properties window click the Driver tab.
    5. Click the Roll Back Driver button (If it is disabled, Windows 7 does not have a previous driver to roll back to.)
    6. Click the Yes button and the previously installed driver should now be restored.
  4. Posts : 21
    windows 7 32 bits
    @ Invader thanks but it gave only some minor chnages ( and btw the default 4.56 m distance is not a proper one?)
    @Marsminar Im glad someone have briefly responded to this but I cannot say im glad Im on this forum cause from start u know someone has an headache and doesnt know what else to do :)))
    I installed the updated driver from Realtek site just as an hint for making a relatively new game stop crashing.
    You could be surprised but I did restore my sistem previously with some days before this upgrade but the audio quality was still very crappy ( I know the difference cause I listen music everyday ). So I I laredy done that rstore I cant make another since the other past restore points weer deleted. The roll back driver is disabled obviously cause Ive done that restore and doesnt have a previous driver to roll back to. HELLLPPPPPPPPPPPPPP!!!!!!!!!
  5. Posts : 54
    4.56 meters is like 15 feet away. I don't know about you, but my speakers are only 3 feet away and it makes a big difference for me.
  6. Posts : 21
    windows 7 32 bits
    Well its not so loud amymore but nothing happend relative to sound quality.I will try to give more information
  7. Posts : 21
    windows 7 32 bits
    Helpppppp?
  8. Posts : 21
    windows 7 32 bits
    Somebody???????????
