Realtek HD Audio Drivers - Constantly detecting/undetecting front jack
Hello all,
I rercently came with the following problem without any reason:
I have a realtek audio chipset with my mother board.
Since some time, the HD audio drivers keeps on detecting/undetecting a device plugged in my front jack (resulting is sound cutoff, which is more than annoying). But, there is nothing plugged.
If I plug something then, the detection works right.
I'm wondering if it is a software problem, or if there is something wrong with my motherboard or my front jack connector (some kind of shortcut or whatever).
If someone as a solution I would really appreciate.
Thanks a lot in advance !
I cannot uncheck the "reload" option in the realtek driver because I need to have this detection working right.
