sound suddenly not working
  1. Posts : 87
    Windows 7 Pro x64
    i have a sound card, sb audigy. suddenly it is not working. my computer was accidentally unplugged when on.
    in control panel, it says the SB Audigy sound card cannot start, (code 10). tried to update drivers to no avail.
    any ideas? this happened once before too. i think it just started working again back then after multiple re-boots.
    thanks.
  2. Posts : 1,261
    Windows 7 Professional X64
    thanks.
    I had a similar problem recently.
    I checked Services and found it was set to Stop.
    Attached Thumbnails Attached Thumbnails sound suddenly not working-dev-mgr-svcs.gif
  3. Posts : 391
    Windows 7 Ultimate SP1 (32-bit)
    Click Start > Type in Search "msconfig" > Go to Services tab > Check if Windows Audio is checked > Apply Then restart
  4. Posts : 87
    Windows 7 Pro x64
    which item under services was set to stop?
    thanks.
  5. Posts : 1,261
    thanks.
    I don't recall at the moment, but see if yours is.
  6. Posts : 87
    Windows 7 Pro x64
    i see it is already checked.
    btw, i have an on-board audio chip, and a plug-in sound card that is used instead.
  7. Posts : 391
    thanks.
    Windows Audio service should be in Automatic
  8. Posts : 391
    So your on-board audio chip is disabled? USB sound card or PCI Express?
  9. Posts : 87
    Windows 7 Pro x64
    it's pci express; i unplugged and plugged it in. i don't recall how i disabled the on-board chip long ago.
  10. Posts : 87
    Windows 7 Pro x64
    IanDrexP said:
    thanks.
    it is. i take it unplugging the computer when it's on can do something bad?
