Weird sound problems, Audigy 2 ZS.
Page 2 of 2 FirstFirst 12
  1. Posts : 4,280
    Weird sound problems, Audigy 2 ZS.-picture-clear-cmos-chaper-2-p19.pngTo clear the cmos refer to chapter 2 page 19 of your user manual I got thes from the online PDF. jumper location Clearing the CMOS sets your bios to default settings. Your manual shows 3 PCI slots have you tried it in a different slot? I think you have a bad ISO. You need to download the enterprise edtion form MS it has a 30 day trial.
  2. Posts : 22
    Windows 7 Ultimate 32-bit (6.1, Build 7600)
       #12
    I don't think i have a bad ISO, since i had the same problem when i had Ubuntu, and i fixed it with taking the whole Sound Card out of the computer. Im gonna try that thing u got there from the manual in a sec.
  3. Posts : 22
    Okay, the weird thing happened again. I simply tried to plug in straight in to the sound card, and not in the green one, and it started to work again, i got sound o.O I'm never going to plug it out again although i hope it doesn't disable when i restart the computer. Wish me luck!
  4. Posts : 4,280
       #14
    Their seems to finally be an updated realtek driver that works. Also if your having to use a different port (one other than the green) it sounds as if windows isn't mapping your ports properly. Here is a thread on the remapping process Realtek HD Changing Jack output reassignments ( FIX ) Of course this would mean going back to the on-board sound which in your case form looking at your MB manual only has 3 jacks to begin with. and this doesn't address the 2 ZS card.
  5. Posts : 1,114
    Windows 7 Home Premium 64 bit
       #15
    Hi Spidah
    I know i'm getting into this discussion late, but having an Audigy ZS Gamer myself i have a couple suggestions. First get the latest Vista drivers from Creative, install them in compatibility mode. Then set up the sound in Windows, you also have to set it up in Creative as well. If you don't set it up in both places it will not work. Hope this helps.
    Smitty
  6. Posts : 22
       #16
    1Bowtie said:
    Hi Spidah
    Smitty
    Thanks for the post, but how to install them in compatibility mode? or how do u set them up in creative to be correct setups?
  7. Posts : 8,870
       #17
    Spidah said:
    1Bowtie said:
    Hi Spidah
    Smitty
    Just right click on the driver file and choose to install in Vista compatablity mode.
  8. Posts : 22
       #18
    chev65 said:
    Spidah said:
    1Bowtie said:
    Hi Spidah
    Smitty
    Okay, so how do i setup the creative setups?
