Creative Sound Card Problem Thread
Page 7 of 16 FirstFirst ... 56789 ... LastLast
  1. Posts : 38
    Windows 7 Professional 64-bit
       #61
    thunder2008 said:
    Done
    Thunder2008 -
    I suggest adding system RAM to your listing since it clearly is a causal factor in the crackling and popping issue. (I have 6GB.) Also, it would be worthwhile to cross-check the list against postings and add any missing posters who did not list their hardware in the body of their post, but included it in "My System Specs".
    Dale
    P.S.
    Please click on icon above and add to my reputation if you have found my posts to be helpful.
  2. Posts : 2
    Windows 7 7057
       #62
    Not sure if this has been mentioned, but Creative has put up a FAQ and a driver compatibility matrix here for W7 (Sorry if the links are not working, but the Creative site can be a bit tricky sometimes in regards to location etc.)
    Some interesting tidbits of information in there. One item that got my attention was this line from the compat matrix:
    Audigy 2 ZS (SB0350) TBC
    Hmm.. It seems my Audigy 2 ZS is not supported yet in the same way as X-Fi and others are supported, with "Beta driver available".
  3. Posts : 93
    Windows 7 RC 7100
       #63
    dsopocy said:
    Thunder2008 -
    Dale
    Hi Dale,
    Yes your quite correct in that ddr is a factor with the audio as well as other issues. While that saying about 32bit os needs 1-3max gb and 64bit needs 3 or greater.
    Was something that I was able to wiggle thru with my 2gb with the 2000mhz+ speeds, but since changing over to W7 the increase in performance of the latter is much more wanting in capacity.
    Ddr3 has also dropped in cost over the last year dramatically~! I once purchased 2gb of pc3-12800 for $500 Ocz flex 1600mhz, now the new flex II 4gb are $180...wow!
    Only thing is if I am going to spend any more money on any ram, cpu or mb it will be for the new i7 line, thus the only reason I still have 2gb instead of 6gb.
    I will check on all posts to the thread and update those with sigs:)
  4. Posts : 15
    Just my two (euro)cents.
    I got an abit ic35, intel q6600, 2x2 Gb of ram and an audigy 2zs.
    With the default windows 7 drivers I would get horrible sound distortion after 10-15 mins in games and movies.
    I found on my hard drive a set of drivers titled "SBAX_PCDRV_LB_2_18_0001" and since installing them I have no problem whatsoever.
    That's in build 7057
  5. Posts : 288
    Windows 7 64-bit
       #65
    Lucky you! Those drivers never made any difference to my problems when I had my Audigy.
  6. Posts : 38
       #66
    Crackling and Popping Problem MAY Be Solved (Well, not solved, but much improved)
    I just finished an upgrade install of the 64-bit Build 7068 leaked yesterday and the crackling and popping has all but disappeared under non-gaming use. I'm using my full 6GB RAM for the first time with Windows 7 without triggering this problem. After living with 64-bit Build 7068 and playing streaming music from Pandora and some Media Player all day, I can say the problem has certainly been addressed, but is not quite 100% fixed.
    I had no sound issues when Build 7068 started for the first time. When the screen saver was triggered, I lost sound which did not return when I logged back in or even resorted to the "Change Sampling Rate" trick. After a cold boot, I heard some crackling and popping on startup system sounds, but once the system was fully loaded, system sounds and music playback were fine with no crackling and popping. I still lose sound after the screen saver is triggered, but simply toggling sampling rates restores sound for the rest of the session. I'm hoping these eccentricities are due to the fact I performed an upgrade install of Build 7068 and they'll disappear entirely with a clean install or future builds. In any case, MAJOR PROGRESS!!!
    Dale
    P.S.
  7. Posts : 1
    Vista x64
       #67
    Creative X-Fi Popping
    I have a problem with my Creative X-Fi Platinum popping and crackling, even with sound muted, under Vista and Win7. I also have an ATI HD4870 installed. The ATI drivers install an ATI Function Driver for High Definition Audio - ATI AA01. If you disable this driver in the Device Manager the popping and crackling go away.
  8. Posts : 15
    Seven 7100 - Mac Osx for iPC - Xp too - of course!!
       #68
    Hi all...my english is not so good, but i need tell all you, that my all problems with driver's is over...becouse the program DRIVER MAX is espetacular (realy works everething!!!) The last upgrade from Microsoft to my SB Audigy 24bits is no compare with the best driver with put on my PC from DRIVER MAX UPGRADE (OR UPDATE DRIVERS)...ITS AWESOME - AMAZING!!! DriverMax - free driver updates !!!
  9. Posts : 458
    Windows 7 7600 x64 (16385) Ultimate,Windows Vista x64 Ultimate
       #69
    ive never trusted those 3rd party auto driver update programs, you just never know what they are doing. but if they work for you then congratulations. maybe it could be worth a shot.
  10. Posts : 15
       #70
    Dear Bloke, im not trusted too, but if you never try, you not realy shure...you get it!? See you around!!
