No sound - help please!
Page 4 of 5 FirstFirst ... 2345 LastLast
  1. Posts : 13,354
    Windows 7 Professional x64
       #31
    Hello, axxo. Welcome to the forums! Could you please post you system specs?
    https://www.sevenforums.com/general-d...tem-specs.html
  2. Posts : 9
    Windows 7 Ultimate 32bit
       #32
    hello Jonathan King! i have posted some system specs. all drivers are installed without a problem and the sound driver to, but there is no sound.
  3. Posts : 13,354
       #33
    Please go back a few pages and review everything I told Stephen Pollard.
  4. Posts : 9
       #34
    ok, here is the screenshot control panel -> sound. i hope it can help
    Attached Thumbnails Attached Thumbnails No sound - help please!-untitled.png
  5. Posts : 13,354
       #35
    Run msinfo32.exe and tell me what BIOS you have.
  6. Posts : 9
       #36
    Bios version: American Megatrends Inc. P1.50
  7. Posts : 13,354
       #37
    Okay, reboot you computer and enter the CMOS. This is usually by pressing F2 or Del during the POST. Navigate to the Advanced tab, and select "Chipset configuration". Confirm that any audio options are set to Enabled.
    Caution: messing around in the CMOS is risky. Do not change values unless you know what you are doing.
  8. Posts : 9
       #38
    I've done just as you said, all audio option are enable. in the device manager in the general tab i have this message: This device cannot start. (Code 10)
  9. Posts : 13,354
       #39
    Click "Troubleshoot".
  10. Posts : 9
       #40
    OK, and this writes there:
    Attached Thumbnails Attached Thumbnails No sound - help please!-1.png   No sound - help please!-2.png
