Help with sound devices
  1. Posts : 8
    Windows Home 36bit
    Hello I installed a reboot system and now I'm gone Stereo Mix I wanted to know how to return it?
    Usually, installing the correct sound hardware driver (e.g. Realtek, Conexant, etc) is needed. If you only have the generic, basic function Windows Installed High Definition Audio Driver (Codec) that does not include Stereo Mix.
    However, if it is available, go to the Sound Panel, Recording section. RIGHT click in a blank area in that panel and then LEFT click to Show Disabled and Disconnected Devices. If Stereo Mix is available it will now be listed and you can set it as default.
  3. Posts : 8
    Windows Home 36bit
    Hi I've installed DoubleTree Realtek and still do not have a Stereo Mix
  4. Posts : 8,135
    System specs are needed for further assistance. PC Brand and Model Number or motherboard brand and model if its a custom built.
  5. Posts : 8
    Windows Home 36bit
    How do I find all the details?
    And this desktop computer is not only portable to general knowledge
  6. Posts : 8,135
    Speccy program may help you.
    Speccy - System Information - Free Download
  7. Posts : 25,847
    Here is another suggestion. A tutorial by Brink.
    System Info - See Your System Specs - Windows 7 Help Forums
    Jack
  8. Posts : 8
    Windows Home 36bit
    Jack
    I have Windows 10
  9. Posts : 8
    Windows Home 36bit
    It does not let me download
  10. Posts : 8,135
    If you have Windows 10, we have a forum specifically for Windows 10 Windows 10 Forums
    Here is an alternate site to download speccy
    Download Speccy 1.30.730 - FileHippo.com
