Win7 64 bit no exclamation event system sound in programs
  1. Posts : 58
    Microsoft Windows 7 Professional 64 bit 7601 Multiprocessor Free Service Pack 1
    From days sometimes win7 don't play the alarm sound in programs when for ex close an unsaved doc or in autocad when make some Operations. I updates all realtek high Def drivers all sounds works but the alert give me problems is it a bug ?
  2. Posts : 2,798
    Windows 7 x64, Vista x64, 8.1 smartphone
    Check the Windows Sound customisation.
    You can Test Windows sound effects from the Sound Window.
    You can follow this tutorial if you wish for more help.
  3. Posts : 58
    Yes I test the win sounds and they work fine .reinstall new audio driver disable nvidia audio and use only realtek .I test all thing at this Point i think is a bug .it happen 1 time yes and one time no ...
  4. Posts : 1
    Windows 7 Ultimate x32, Windows 10 x64
    Facing the same problem in Win 7 32. While testing it works for me everytime, but while working, when it should sound, it doesn't. Strange bug!
  5. Posts : 58
    Ok it is good that happening to you
    Shit microsoft
