No sound from any sound device.
  1. Posts : 25
    Windows 7 Professional 64-bit Service Pack 1
    The sound on my HP Envy Pheonix 810-135qe was working fine yesterday, turn on the machine and there is no sound from any device at this time. I cannot get sound from the monitor speakers, external PC speakers or the headphone jack. Also I cannot see the speakers in the device manager. Would a system restore to a previous date correct the problem? I have performed all the tests that Windows provides, but to no avail. Any help will be greatly appreciated.
    System info:
    HP Envy Phoenix 810-135qe
    10GB RAM
    OS Version: Microsoft Windows 7 Professional, Service Pack 1, 64 bit
    Processor: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, Intel64 Family 6 Model 60 Stepping 3
    Processor Count: 8
    RAM: 10193 Mb
    Graphics Card: NVIDIA GeForce GT 640, -1 Mb
    Hard Drives: C: 1846 GB (1707 GB Free); D: 16 GB (1 GB Free); F: 931 GB (0 GB Free);
    Motherboard: Hewlett-Packard, 2AF3
    Antivirus: Spybot - Search and Destroy, Enabled and Updated
    Attached Thumbnails Attached Thumbnails No sound from any sound device.-sound.jpg
  2. Posts : 0
    Did you install a progarm or an update prior to this happening?
    Go to Device manager. Type dev into search and you'll see it. Are there any yellow exclamation marks?
    You can try downloading the audio driver here and reinstall:
    https://support.hp.com/us-en/drivers/selfservice/hp-envy-phoenix-810-100-desktop-pc-series/5399342/model/6667348
    Are you currently getting audio through your monitor via HDMI?
    A system restore might help.
  3. Posts : 25
    F22.....thanks for your reply. After doing a bit of fiddling I was able to get HDMI audio through my monitors. I also have an old surround stereo connect via a "Y" cable in thew headphone jack, that is now working. I cannot get my Logitech Z 640 PC surround sound system to work. Its an old product but it has performed well since day one of purchase. Below is a screenshot of the sound properties.......
    Attached Thumbnails Attached Thumbnails No sound from any sound device.-new-sound.jpg
  4. Posts : 0
    Okay, the reason why you may not have surround sound is that you may need to go to the sound settings driver or your audio properties and make sure you're using 5.1 or 7.1 what ever the case may be.
    You can try this by right clicking the IDT device (not sure which one) and select properties. In there may just be the 5.1 or 7.1 option. Also look for an audio driver program to select those settings. It may in fact have its own icon in the task bar bottom right. Or you can search though the Start orb or in your programs.
