[HELP] No Sound Card Detected
  1. Posts : 6
    Hi, i've installed windows 7 yesterday and i found 2 problems that i want to resolve with your help.
    My motherboard is the ASUS P5Q PRO and i've already download 5 or 6 drivers and nothing happen.
    In device manager don't appear the Sound Device.
    What's missing ?
    The second problem is that my USB when i put something it always appears as Unknown Device, and i've tried with diferent objects
    Help me please.
  2. Posts : 18
    Hi, Having a similar problem with a Medion laptop (Intel core duo 1.8GH and 3G ram) annd W7.
    The Realtek sound card is showing in Device Manager and shown working correctly and indeed it plays CD or sound from streaming. However in Sound Control Panel the only device for playback is the speakers; and for recording only the microphone is listed. No mention of Realtek. Plugging a USB sound card in gives the same result; in Device mgr but only speakers and mike in Sound. This means I cannot do VOIP or record from streaming directly. I have to link the speaker output by 3.5 mm jacks to Mic input to record streaming. No good for VOIP. VOIP programs state no sound card found. Any ideas please?
  3. Posts : 6
    no one can help ?
  4. Posts : 6
    i'm waiting guys :\
  5. Posts : 1,797
    Windows 7 Ulti. x64
    wAZ0R said:
    i'm waiting guys :\
    Welcome to SevenForums,
    I found this windows 7 driver, you may give that a try if you have not. Good luck to you with this problem.
    ASUSTeK Computer Inc.
  6. Posts : 6
    i've already tried it on
  7. Posts : 1,797
    Windows 7 Ulti. x64
    Have you tried to use the vista drivers in compatibility mode?
    Compatibility Mode
  8. Posts : 6
    yes, i've tried that to.
  9. Posts : 18
    I have had the same problem now for eight months. I am using a Medion laptop and a Realtek sound card. I can play audio from CD/streaming ewtc, but the only listed method of recording is by Mic or Line input. Been and got the latest driver (Dec2009 release) but it is not showing in Control Panel/Sound. I have worked around the system by using a single to double 3.5 adapter and plugging a short lead from one of the outputs back into the line input (with the external speakers in the other output) and this allows me to record streaming sound.
    I do wonder if the Realtek sound card is a proprierty model built for Medion; but I have a USB C-Media sound card and the drivers load and sound can be played back through it but recording is limited again to Mic/Line input.
    Is there some sort of security setting (or registry setting) in W7 which needs changing to allow a sound card to be used for recording? I am now trying to investigate this option. Have not got very far as yet.
    Device manager listsd both sound cards as 'Working properly'
  10. Posts : 4
    win 7
    no sound detected
    Try this
    Control Panel... Sound... Recording Tab...
    Right click on any entry, Show Disabled Devices, make sure Stereo Mix is enabled. Should work for you.
