No Sound
Page 1 of 3 123 LastLast
  1. Posts : 8
    No Sound
    Hello everyone!
    My computer is old and my uncle recently reprogrammed everything and installed Windows 7. Before it was fixed everything worked fine but now there is no audio. There is a speaker icon in the bottom right corner of the screen that says "No Audio Output Device is Installed". I don't know much about computers so any help I can get is greatly appreciated. Thanks guys!!
  2. Posts : 239
    Looks like there were no audio drivers installed. Have you installed the drivers for your motherboard from the manufacturers website? Do you know what type of motherboard you have? :)
  3. Posts : 8
    sorry i don't know what type of motherboard i have. is there anyway i can find out? if there is i'll gladly look and let you know
  4. Posts : 239
    This little gem right here will help you with that. It's called CPU-z. Install it, then run it and it will tell you which motherboard you have. You can paste a screenshot or the information here for more assistance :)
  5. Posts : 8
    CPU-Z Readme file
    Version 1.53
    December 2009
    Contact : cpuz@cpuid.com
    Web page: CPUID
    Validation page : CPU-Z Validator 3.00
    Hall of Fame : CPU-Z Highest Records ! (V1.01)
    Forum : CPU-Z Official forum - Canardpc.com
    CPUID SDK : CPUID Developers Corner
    Configuration file (cpuz.ini)
    The configuration file must be named cpuz.ini and be present at the same directory level
    as cpuz.exe. It contains the following :
    [CPU-Z]
    TextFontName=Verdana
    TextFontSize=13
    TextFontColor=000060
    LabelFontName=Verdana
    LabelFontSize=13
    PCI=1
    MaxPCIBus=256
    DMI=1
    Sensor=1
    SMBus=1
    Display=1
    ShowDutyCycles=0
    - TextFontName : Font used for the information boxes.
    - TextFontSize : Size of the font used for the information boxes.
    - TextFontColor : Color of the font used for the information boxes. Value is expressed in hexadecimal, and consists in a classic Red/Green/Blue color code : RRGGBB
    - LabelFontName : Font used for the label boxes.
    - LabelFontSize : Size of the font used for the label boxes.
    - Sensor : Set to OFF (or 0) disables sensor chip detection and voltages measurement. 1 to enable.
    - PCI : Set to OFF (or 0) disables the PCI information. This disables chipset, SPD and, depending on the hardware, sensoring information. 1 to enable.
    - MaxPCIBus : Sets the maximum PCI bus to scan. Default value is 256.
    - DMI : Set to OFF (or 0) disables the DMI (Desktop Management Interface) information. This concerns BIOS vendor and version, motherboard vendor and revision. 1 to enable.
    - SMBus : Set to OFF (or 0) disables SMBus information : SPD, and, depending on the hardware, sensoring information. 1 to enable.
    - Display : Set to OFF (or 0) disables the video card information reported in the validator. 1 to enable.
    - ShowDutyCycles : Set to 1, switches the alternate clock computation method based on duty cycles. 0 to disable.
    Parameters
    -txt=filename : Launch CPU-Z in ghost mode (no interface appears) and generates the register dump file (.txt)
    in the same directory as the exe file.
    -html=filename : Same as "-txt" except it generates the html report.
    -core=id : Displays clock speed of core #id (id can be set from 0 to Number of cores minus one).
    Keys
    F5 : save the current tab in a bmp file
    F6 : save the current tab in the clipboard
    F7 : save cvf file in the current directory
    Cache Latency Tool
    The cache latency tool can be downloaded at that address : http://www.cpuid.com/download/latency.zip
    History
    1.53 - December 2009
    - Fix validation issue with AMD Phenom processors (1.53.1).
    - Preliminary support for Intel Pinetrail platform (1.53.1).
    - Intel Core i7 930 & 950, Core i7 980X "Gulftown", Xeon W3565.
    - Intel Mobile Core i7/i5/i3 "Arrendale" (LV and ULV).
    - Intel "Clarkdale" platform improved support.
    - AMD Phenom FX-5000, Athlon II X2/X3/X4, Athlon L110.
    - AMD AM3 socket detection improved.
    - VIA VX800 and VX855 chipsets support.
    - ATI Radeon 2100 and Radeon X1250 support.
    - DirectX 11 detection fix.
    - Hardware virtualization support now reported as instructions set.
    - New HTML report with less information.
    1.52 - July 2009
    - Fix Core i7 clock bug (1.52.2)
    - New design with "Graphics" tab.
    - NVIDIA nForce 980a chipset support.
    - Intel Core i5 and Core i3 processors.
    - Intel Atom Z530, Pentium DC E6300 (2.8GHz) and Core 2 Solo processors.
    - Intel P55 and US15W chipsets preliminary support.
    - AMD Phenom TWKR support.
    - AMD Phenom X2 "Callisto" and Athlon X2 "Regor" processors.
    - AMD Opteron 6-core "Istanbul" processor.
    - Improved support for Windows 7.
    - New Intel logos.
    MD5 checksum : please refer to CPUID
    1.51 - April 2009
    - New version with installer.
    - NVIDIA ION platform.
    - Intel "Clarkdale" processor preliminary support.
    1.50 - February 2009
    - Improved support for AMD Phenom II processor.
    - Support for NVIDIA 740i chipset.
    - Several bug fixes.
    MD5 cpuz.exe (1.50) : E1C827C54F527404EDDA6D65DA0280D8
    1.49 - December 2008
    - AMD Phenom II processor.
    - New Intel Core 2 models.
    - Improved loading time.
    - New online validation process.
    MD5 cpuz.exe (1.49) : B836E86B40D7AFAF99D9C512E8CC9FEF
    1.48 - October 2008
    - Improved support for Intel Core i7 (Bloomfield & Gainestown).
    - Intel Atom dual-core version support.
    - AMD Athlon "Kuma" processor support.
    - Alternate clock computation method based on "duty cycles" for Intel Core 2 processors (see ShowDutyCycles in cpuz.ini)
    MD5 cpuz.exe (1.48) : DB78FBF1F99B7709240B495E59758CCE
    1.47 - August 2008
    - Intel Core i7 processor.
    - Intel Core 2 Duo S Mobile processors.
    - NVIDIA MCP79/7A chipset.
    - AMD 790GX / SB750 chipset.
    MD5 cpuz.exe (1.47) : A7484EFA3C32BC968C248CB1237FF493
    1.46 - June 2008
    - AMD Puma platform (Turion & Turion Ultra "Griffin");
    - AMD Black Edition processors.
    - Intel Xeon EX "Dunnington".
    MD5 cpuz.exe (1.46) : C47432C41EC26156128F7B8E09E884CF
    1.45 - May 2008
    - Intel Atom Z500/Z510/Z520/Z530/Z540 processors.
    - Intel Core 2 Duo E7x00 processor.
    - AMD 45 nm Phenom (Dened & Shanghai) processors.
    - Intel P45 chipset.
    MD5 cpuz.exe (1.45) : DD4E540C04297CF93DC721166C13446E
    1.44.2 - Mars 2008
    - NVIDIA 650i, 680i, 750a/780a, 750i, 780i, 790i chipsets (1.44.2)
    - Intel G35 chipset (1.44.2)
    - Updated support for VIA chipsets (1.44.2)
    - Support for the new validator (1.44.1)
    - Preliminary support for VIA Isaiah processor.
    - Support for all VIA Model D processors: VIA C7-M, VIA C7-D, VIA Eden, VIA Eden.
    - Memory timings on Intel 5400A/B MCH (Skulltrail).
    - Fix AMD Phenom detection issue on Windows Vista 64.
    MD5 (1.44.2) : 81FB48A6EC7355E8D0DD71ADC2157CF6
    1.43 - January 2008
    - Intel Skulltrail platform support (Core 2 Extreme QX9775 + 5400B MCH).
    - Intel X48 chipset detection.
    - AMD Athlon 64-LE 1600 and 1620 support.
    - Fix detection issues on unlocked Phenom (ES/BE).
    1.42 - November 2007
    - Intel Wolfdale/Yorkfield/Penryn CPUs support.
    - AMD Phenom and Opteron Barcelona support improved.
    - Current core selection menu (right click on the CPU page).
    - Loading progress.
    1.41 - September 2007
    - New CPU voltage monitoring.
    - Intel Xeon Tigerton support.
    - Intel IA64 CPUs support (Itanium / Itanium2)(special thanks to Rami Radi and Ray Hinchliffe).
    - AMD K10 Phenom preliminary support.
    - NVIDIA MCP73 support.
    - Intel XMP profiles support.
    - Memory modules nominal voltage.
    1.40.5 - July 2007
    - NVIDIA nForce 560 chipset support.
    - Intel Dynamic FSB technology support.
    - Athlon 64 X2 BE & Sempron LE (TDP 45W).
    - SiS671/FX/DX/MX northbridge support.
    - SiS968 southbridge support.
    1.40 - May 2007
    - VIA P4M800CE chipset support.
    - Preliminary support for Intel Penryn CPUs family (45 nm).
    - Intel Core 2 Duo E6x20, Pentium E2140/2160 processors recognition.
    - Intel P35, G33, G31, Q35, Q33, X38 chipsets support.
    - Intel GL960/GM965/PM965 chipsets support.
    - AMD Athlon 64 "Lima" processor support.
    - AMD Geode LX processor support.
    - NVIDIA nForce 520 chipset support.
    - New parameter "-console" to generate output in a command prompt (Windows XP only).
    - New icon.
    1.39 - February 2007
    - Windows Vista 64 support.
    - VIA CX700/VX700 chipset.
    - Added Merom XE (X7900/X7800)
    - Added "PCI" and "MaxPCIBus" in the ini file to configure PCI scanning.
    - Added "-core" parameter to display the clock speed of the specified core.
    - Lot of bug fixes.
    1.38 - November 2006
    - VIA P4M890 and P4M900 chipsets.
    - NVIDIA 650i and 680i chipset.
    - AMD Athlon 64 FX-7x processor.
    - Core 2 Duo E6850, E6750, E6650 processors.
    - socket 775 Xeon processor.
    - New parameters "-txt" and "-html" (see above).
    - Lot of bug fixes.
    1.37 - October 2006
    - Intel Core 2 Quad, Celeron 360, Mobile Core 2 Duo T5200 support.
    - Changed SSE4 to SSSE3 (Supplemental SSE3).
    - Added VIA VT8237A southbridge.
    - New HTML report.
    1.36 - August 2006
    - New processor information display.
    - Intel 5000X/P/Z/V SPD support.
    - Intel Pentium D 925 & 945.
    1.35 - June 2006
    - ATI RS350, RS400, RS480/RX480, RS482, RD580/RX580, RS600/RD600, RS690, RS700 chipsets support.
    - ATI SB600 southbridge support.
    - Intel P965 chipset support.
    - Engineering samples Core based CPUs report.
    - Windows Vista product line report.
    1.34.1 - May 2006
    - AMD socket AM2/S1/F (rev F.) CPUs support.
    - Enhanced Performance Profile (EPP) memory information report.
    - Added Trc (bank cycle time) in DDR2 SPD report.
    - Added Trc (bank cycle time) on i925, i945, i955, i975 chipsets.
    - FB-DIMM DDR2 SPD information report.
    - Core 2 Duo names and logos added.
    - Turion 64 X2 logo added.
    - Several bug fixed.
    1.33.1 - April 2006
    - Intel i965 chipset support added.
    - Fix SPD detection problem on SiS 964/965/966 southbridges.
    - ODC (Odd Divisor Correct) for Athlon64 rev E.
    1.33 - April 2006
    - Memory Command Rate timing added.
    - Improved support for Intel Conroe/Merom CPUs.
    - Celeron M 420/430 Yonah.
    - Xeon Dual core Dempsey.
    - VIA C7-M CPU detection added.
    - VIA PT880, PT880 Pro, K8T900 chipsets support.
    - nVidia nForce 550/560/570 (MCP55) chipset support.
    - VIA VT8251 southbridge support.
    - Fixed HyperTransport information misreports (in dump file).
    - Added K6-2 and K6-III logos.
    1.32.1 - March 2006
    - New Intel logos.
    - Added Pentium D 925, Pentium EE 965.
    - Several bugs fixed.
    1.32 - February 2006
    - Athlon FX-60 detection added.
    - Athlon64 new memory dividers.
    - Celeron 35x Cedar Mill, Pentium D 805.
    - Core Solo & Core Duo detection improved.
    - VIA C7 CPU detection added.
    - Intel i975X, i945GT chipsets support.
    - ATI RD580 chipset support.
    - ULi smbus support improved.
    - Fix smbus conflict with ClockGen.
    1.31 - November 2005
    - Improved support for ATI RS480/482 chipsets.
    - GeForce 6100/6150 (nForce 410/430) chipsets support.
    - Intel E7520 chipset support.
    - New CPUs support : AMD Opteron socket 939, Intel Pentium 4 Cedar Mill and Presler,
    Intel Xeon Paxville, Intel Pentium M Yonah SC & DC.
    1.30 - August 2005
    - Latest Sempron and Turion support improved.
    - Intel Xeon Potomac, Pentium M 780 support.
    - Improved Windows version report.
    - Support for SMBus on latest SiS bridges (964, 965, 966) and ULi bridges.
    - Increased clocks refresh rate.
    1.29 - June 2005
    - New PCI devices report.
    - Switch for VCore report in .ini file.
    - VCore report on some uGuru mainboards.
    - Improved clocks computation.
    - Improved support for latest AMD CPUs, Celeron D 3x1 (EM64T).
    - Improved support for SiS 649, 650 and 656 chipsets, Intel 915PM chipset.
    - Improved stability when several instances of CPU-Z are running in the same time.
    - Restored html report in ghost mode (see "Parameters" chapter above).
    1.28.6 - March 2005
    - Support for Athlon 64 X2 CPUs
    - Support for i955X chipset
    - Bunch of bugs
    1.28 - March 2005
    - Support for SiS chipsets improved : 648FX, 649, 655FX, 655TX, 656
    - Support for nVidia nForce4 SLI Intel Edition
    - Support for Intel Pentium D, Pentium XE, AMD Turion, Opteron 252
    - New F7 key to simplifiy the creation of the validation file
    1.27 - February 2005
    - Support for Intel Pentium 4 6xx CPUs.
    - New validation system.
    - Hundred of bug fixes.
    1.26 - December 2004
    - VCore display on Pentium M CPUs.
    - New CPU clock computation.
    - Improved support of Transmeta CPUs.
    1.25 - November 2004
    - nVidia nForce4 chipset support
    - Intel Pentium 4J support
    - New button to refresh memory timings
    1.24 - September 2004
    - AMD Sempron support
    - New memory SPD page
    - PCI-Express graphic interface support
    - Configuration file
    - External cache latency tool
    - Fix several bugs
    1.23 - June 2004
    - Intel i915P/G, i925X chipsets support
    - Intel LGA775 CPUs support
    - Intel's CPU number display
    - New AMD Athlon 64 steppings
    - New report in one file
    1.22 - April 2004
    - New CPUs : Xeon Nocona, Celeron Prescott
    - DDR2 memory support
    - Clock mode when iconized
    1.21 - January 2004
    - one file package
    - Windows 64 support
    - new chipsets support
    - new CPU support : Celeron M, Pentium 4 "Prescott"
    1.20a - October 2003
    - memory frequency and ratio on nForce2
    - KT600 support
    - W83627THF VRM mode
    - SPD read improvement
    - Fix some memory leaks (DMI)
    - Fix memory size report
    - Fix AGP side band status
  6. Posts : 239
    Hehe. That's the readme file for the software. Not your information :)
  7. Posts : 385
    In this regard, I guess he may be having a Conexant audio device. This device will give similar issues which has happened with me 3 times with 2 different Laptops and a PC
  8. Posts : 8
    whoops! sorry lol. like i said i don't know much about computers haha...
    MOTHERBOARD
    Manufacturer: (it's blank)
    Model: P4M266A-8235
    Chipset: VIA P4M266 (VT8751) Rev. 00
    Southbridge: VIA VT8235
    BIOS
    Brand: Phoenix Technologies, LTD
    Version: 6.00 PG
    Date: 5/27/2004
    GRAPHIC INTERFACE
    Version: AGP Version 2.0
    Transfer Rate: 4x Max Supported: 4x
    Side Band: not supported
  9. Posts : 908
    Windows 7 Home Premium
    [QUOTE=solarpower;632062]whoops! sorry lol. like i said i don't know much about computers haha...
    MOTHERBOARD
    Model: P4M266A-8235
    You weren't kidding when you said old.
    Machine: Via Technologies P4M266A-8235 Motherboard
    CPU options: Intel Pentium 4
    Chipset: VT8233/8233A/8233C chipset
    HD Bus: ATA 33/66/100, ATA-133 with VT8233A South Bridge
    Front Side Bus options: 200/266 MHz FSB
    Memory Speed options: PC2100 184pin DDR266 DIMM
    Good luck getting this to work, you will need some kind of AC97 style driver.
    Ok, it may be a Biostar motherboard
    Biostar USA
    Ap
  10. Posts : 197
    Windows 7 Enterprise x64
    hwinfo32 may help you, you can download the program here:
    HWiNFO & HWiNFO32 - Hardware Information and Analysis Tools
    It's a neat little free program.
    -Bill
