Creative X-Fi Xtreme Audio
  1. Posts : 5
    Windows 7 RC1 Build 7100
    ive bitten the bullet and installed the x64 version of the RC1.... and all works perfectly now... i find it kinds odd the x64 drivers work for me when the x86 drivers didnt.....
  2. Posts : 4
    Windows 7 x64
       #12
    try this
  3. Posts : 7
    Win 7
    I downloaded these drivers for my SoundBlaster X-Fi on Win 7 RC1... it said no compatible device was detected... Am I missing something here??
  4. Posts : 4
    Windows 7 x64
       #14
    are the drivers compatible?
    What kind of Xfi You have?Read that forum and search for your card to be supported.
  5. Posts : 3
    windows 7
       #15
    Many thanks for the PAX PCI XFI Windows 7 V1.20.7z,they did the job,but there is a problem.I have 3 speakers,and all sounds come from all of them at the same time.There doesn't seem to be a different chanel for left,right and centre speakers.Any ideas?
  6. Posts : 4
    Vista x64, Win 7 x64
       #16
    SB P17X Series Support Pack 2.0 (07/31/2009) - Aud... - Creative Labs
    These are based on the LATEST official drivers. They have ALL features working under Windows 7. Enjoy.
  7. Posts : 3
    Windows 7 RC x86 Ultimate
       #17
    For those using PCI-E ver of X-Fi Extreme Audio for 5.1
    Creative Worldwide Support > PCI Express X-Fi Xtreme Audio
    Filename: XFXA_PCDRV_LB_1_04_0000.exe
    Current issue I'm having is not having the mic detected as a mic as it's being detected as a Line-In. I'll try to figure this out (and yes its in the correct jack)
  8. Posts : 3
    windows 7
       #18
    Many thanks,will try them later on today,hope that will fix the problem.
  9. Posts : 5
    I have SB x-fi extreme gamer(PCI) and for w7 64b i use SB X-Fi Series Support Pack 2.0 but XP version,its realy amazing taht vista/w7 drivers dont work. I can install only XP version but works good and in this drivers is THX enabled.
    http://forums.creative.com/t5/Sound-...009/m-p/527485
  10. Posts : 6,879
    Win 7 Ultimate x64
       #20
    SB X-Fi Series Support Pack 2.0 (05/15/2009) - Creative Labs
    And won't work with the Xtreme Audio, before anyone in this thread decides to try this driver.
