Well after i put it into my motherboard, i turned on and then windows said it was trying to detect the driver, so it led me to the download link to download it. After downloading, i tried to install but got that error; nope. i do not have any other PCI slots used by other hardware. This is the only thing i ever putted inside my computer since i bought it.
p.s.
When i check device manager, under Other Devices, it lists Multimedia Audio Controller which has the yellow triangle "!" sign. When i check its properties, it says "the drivers for this device are not installed." Not sure if this has something to do w/ it or not. and it leads to the same download link as when i tried to install the sound card. So i guess it does has to do something with it.
